Rear seat trim repair
Hi everyone,
Anyone had this issue and if yes, how did you fix it?
I have the same problem on both sides... The faux leather from the rear seat trim developed some sort of a "blister".
Thanks
Thanks
I have the same problem with my dash (search for Dash "Bubble"). I've gone to about 5 upholstery shops and no one is able to fix it. They say that with age the glue starts to fail and leads to the separation. They can only put more glue and try to tack it down, but 4 of the 5 places I went to said they won't do it b'c it's not a permanent fix and they don't want to do work they can't guarantee. I'm going to try some Stick 'n Seal glue specifically made for vinyl that was recommended by a guy at Home Depot and then use a pair of C-clamps and a short piece of wood to lock it down. Good luck with your fix, i can let you know how mine goes. I plan to attempt it today.
BTW 5th guy wants $150 and says he can repair it.
here's my update... and ya heat would also be a good attempt but be sure to protect the area and use a clamp or something to put even pressure on it. https://www.clublexus.com/forums/sc-...ml#post8393584
RVAGS400
06-09-18 12:21 AM
