Adding Puddle Lights and Turn Signals
That looks really great - thanks for posting that info. I have always wished the SC had more advanced exterior lights than it does.
(By the way, regarding your first note, there is no such thing as "very unique." You surely mean either "unique" or "very unusual." The fact that the the newsguessers say it on TV does not change the meaning of the word.)
Back to business: I just visited my daughter (to see the new baby) and noticed when she hit the remote for her X5 that little lights illuminated the exterior door handles - I was very impressed as this is unusual, useful and impressive: the trifecta of automobile accessories. I hope my next car (RC350?) has features like that. Even if not useful, I would be satisfied with accessories if they impressed bystanders, as I am quite superficial. Perhaps that's why I like the SC and operate the top in public whenever I can, especially at stoplights where the guy behind me has to look.
Again: good job on that mirror modification.
Thanks for all the props everyone! If I could fly and reproduce these results on everyone's SC430s, I would. I had a week off from work and decided to attack this mod. It was pretty straight forward once I figured out how to open the mirror housing. This was a pretty low dollar mod though. Only about $30 for the lights and materials, but my total increased when I broke my mirror glass and had to purchase an entire used mirror unit for $160. So topped out just under $200. Work time was about 4 hours for both sides but didn't include my overnight drying times for glue to waterproof the units.
As with my case. I recommend if anyone attempts this mod, just be careful with the glass. All other parts are pretty durable. But in regards to the glass, PLEASE PLEASE use a pry tool or tiny flat head screwdriver when actually removing the glass to separate the bottom from the white mounting plate. NOT YOUR FINGERS! Please remove the entire mirror from the car, much easier to work with and then turn the unit upside down so you can see what you're doing. Sewell sells the glass alone for $458 each which can put some pretty big holes in anyone's pocket. Anyway, onto the next mod!
Great job Shawn, very impressive and a superb DIY, well done.
Cheers
Steve
Cheers
Steve
Hey Shawn,
So as you already know I have been interested in this mod for very long but im looking for a simpler way to do this, meaning that I want to avoid trying to cut a shape out of the mirror housing when I can just drill one hole and not because your method has any flaw, I dont want to get too creative and ruin something or have uneven shapes lol..so the question is the area where you placed your LED strip.. is there room to put an "LED Eagle Eye" ? its kind of like a bolt and I mean if there is enough room for its length inward then it would be simple to just put a hole and tighten the bolt? what do you think? my second concern is if the LED head would show from under the mirror.. but I guess ill have to order to see its size properly! i think they come in 1.5w, 3w, i have also seen 9w all per bulb.. not sure though because all of them say around 110lm to 140lm..
apparently there super bright
kind of like the bulb Steve "WIL44" has placed in his reverse light but under your side mirror!
![Adding Puddle Lights and Turn Signals-capturell.png](https://www.clublexus.com/forums/attachments/sc430-2nd-gen-2001-2010/318022d1461367781t-adding-puddle-lights-and-turn-signals-capturell.png)
bimmer, I thought about those eagle eyes too but I really wanted a flush mounted solution that wouldn't be an eye sore (even from behind), so i didn't delve into them too much. I wanted to keep the natural look as much as possible. I looked at the eagle eyes and found that most needed more mounting depth than what is available in the middle of the mirror unit. From my estimations, there would have been no way to mount it so the light would be directed straight downward and remain hidden. Directly under the "joint" where the mirror cover meets the outlining trim around the glass, there is a metal frame that holds all the motor parts and the white backing plate to hold the glass. No way to modify the metal without messing up the components. In regards to cutting into the mirror cover, the good news was if I had screwed up a new cover usually goes for $60 new from Sewell (or ebay $25). My only options was the flat style COB LED in order to keep it flush mounted, fit in the shallow mounting depth, and throw light directly downward. I'm sure the eagle eyes can be done, but just not in the part of the mirror where I've installed mine. They would have to be moved further toward the nose of the car and that would result in them not being flush due to the curvature of the mirror cover. The only true hollow part of the mirror with manipulable space is the mirror cover that has the chrome accent.
Thanks Again!
Ok so enough anticipation! As Tfischer guessed, my plan is to put a switchback LED into the inner part of door handles that will serve as a running light and a turn signal! Should make for a interesting modification! It will keep the OEM look and still serve functional. I'm excited. I've already got the wires in the door panel and run through the grommets so I just have to tie in and possibly hire an electrician to help isolate the signal and parking leads and run into the cabin (unless someone can recommend a good way to tie into the parking bulb and turn signal via fuse box). I've contacted a member here who will work with me on a used handle so I can take my time with the mod rather than rush with my handles or have no way to get into the car. I'll post my progress as it comes together. Here's a little DIY I found, but I will have to mod it more as our handles are slightly different and will be using a switchback LED strip. Wish me luck! https://www.clublexus.com/forums/is-...r-handles.html
Bacardi, the mirror lights are white and actually only light up when the security system arms and disarms- they never blink and are never lit while in motion. The proposed door handle lights will light steady as a parking lamp only and blink yellow only when turn signal is active on each respective side. Checked my Oklahoma laws, and those combinations are permitted, but I assume it's like my illegal tint and up to an officers' discretion. I try not to break any official laws (speeding, running lights, illegal procedures, etc) thus allowing an officer to fine for miscellaneous violations but thank you for the advice.
Sorry for all those that have been eagerly awaiting an update and have PM'd me regarding the next mod; the turn signals and parking light in the handles. The forum member from whom I was hoping to purchase a door handle to experiment with has deemed my endeavor not worth his time to search for the part and/or not worth the offer I made on his salvaged handle. Therefore, I've purchased one online and hopefully will be able to get to this mod this week. I've planned out my wiring already and just need the handle to plan the install. Updates soon friends!
So I've run all the wires from the headlight turn signals into the cab on both sides and have only created the driver's side handle at the moment. Next week, I will finish the passenger's side handle and then make the final connections in the door. I'm thinking of connecting the white running lights to the fog light fuse to allow me to turn them on and off, just in case (and I prefer this method to a true installed switch). Let me know what you all think. Thanks!
Part 2 .... As you can see, I used quick connects so if the light ever burns out then it's an easy replacement without ever having to remove the door panel. I can pretty much change these items out from the exterior of the car and never have to open the interior door panel. Planning is crucial to these types of mods that I attempt. I did the same thing for the puddle light with quick connects. I always plan for future hardware failure. Hopefully I won't ever have to deal with that problem, though. Knock on wood.
DJHydrogen (04-04-20)
