Wind noise
Old 03-13-14, 04:06 PM
Scottb07
Scottb07's Avatar
Default Wind noise
I have an 07 sc 430. It has a wind noise on drivers side. It seems to be at the top of the window where the top fits into the header bar. Any advice! Thx Scottb07
Old 03-13-14, 04:31 PM
ShawnOk
ShawnOk's Avatar
https://www.clublexus.com/forums/sc-...ind-noise.html
Old 03-13-14, 04:36 PM
hlthlnk
hlthlnk's Avatar
First thing I would check is the little rubber triangle next to the door mirror. If you have a crack on that piece you will not get a good seal around the window and you will hear wind coming in. If that is not the case then I would try to lubricate the seal around the window with a little Vaseline. Hope that helps.
Old 03-17-14, 10:45 AM
Harold57
Harold57's Avatar
The weatherstripping typically splits at the top where the window pushes up into it. Once it splits, it creates wind noise. They aren't terribly difficult to replace if you are patient and careful, but it does take a good 20 minutes a side to do, longer the first time.
rvgraham
02-21-18 06:05 PM
RRocket
03-30-17 08:36 PM
karolgt
09-27-14 05:58 AM
Mike_TX
05-21-14 12:09 PM
tomrx330
11-16-04 12:06 AM
Quick Reply: Wind noise
