Cost of brake job
Old 03-13-14, 05:35 PM
janabrock
janabrock's Avatar
Default Cost of brake job
How much should I pay to have my front brake pads changed and the rotars rotated? 2006 SC
Old 03-14-14, 09:29 AM
mrblister
mrblister's Avatar
You mean to have the rotors turned [ cut ] to remove any high spots. The front pads should cost approx. dealer charges parts 125.00 + labor could be at total cost 375.00.
Old 03-14-14, 05:54 PM
texsexlex
texsexlex's Avatar
...I did mine myself....paid $65 for the pads & $20 to have the rotors turned. $85 & about a 1.5hrs of my time
Old 03-14-14, 06:28 PM
StillLine
StillLine's Avatar
Default Toyota Dealer
If you're not interested in getting your hands dirty, check with your local Toyota dealer. They will do the exact same job as the Lexus dealer for possibly quite a bit less.
Old 03-14-14, 07:40 PM
janabrock
janabrock's Avatar
Thanks! Sewell in Dallas charges $330 per axle.
Old 03-16-14, 05:38 AM
OBP
OBP's Avatar
That sounds about right for dealer price. Might want to check if your OEM rotors have the required thickness left to get turned ( cut ). Mine were too thin after I started getting the shakes at about 50 or 55 k miles. Replaced and switched to after market slotted rotors and absolutely no regrets.
Old 03-19-14, 05:23 AM
tromly
tromly's Avatar
, yes my Toyota dealer charged me $210.
Old 03-19-14, 07:42 AM
bacardi11
bacardi11's Avatar
I don't believe in cutting the rotors. when I did my brakes, I got some good rotors and pads and my mechanic replaced them.
no dealership did the work.
Old 03-19-14, 10:51 AM
jzwu
jzwu's Avatar
Cutting the rotors once should be ok.
I have done that to a number of my cars without any issues.
Old 03-19-14, 12:16 PM
UGAALF
UGAALF's Avatar
I am having the airbag recall work done by the dealer now and he just called me and said that the rear breaks were almost metal on metal and needed to be fixed, for $299.
Old 03-20-14, 03:09 AM
iolmaster
iolmaster's Avatar
The pads on the rear should have a squeal tab. They should never have gotten that low without you knowing it.
Naren
NX - 1st Gen (2015-2021)
19
10-31-18 11:19 AM
as90
04-03-18 10:11 PM
CapitalisT
Suspension and Brakes
07-23-09 11:51 AM
zzzzdoc
GX - 1st Gen (2004-2009)
13
06-08-09 08:37 AM
hoonami
06-14-08 03:53 AM
Quick Reply: Cost of brake job
