Interim Sound Solution
Until I have the funds to replace or install new connections I'm trying to get sound from my phone (Spotify and Tune in radio) to my car.
Tried gogroove flex x2 bluetooth - quality was good but everytime I restart the car I lost my pairing to the bluetooth in the NAV system. I only wanted A2DP BT from the X2 and voice BT to the NAV unit. Couldn't find a way to turn off voice BT to the X2. Taking it back unless someone has solution.
I'm stuck with the good ole reiliable tape adaptor and a wire until I can find a solution.
Even with the permanent solutions how do you prevent the BT fighting between devices??
Thanks for any help
Dave
Thanks for any help
Dave
On my android phone under the Bluetooth devices I choose which features I want active for each specific device. I use an Arion Bluetooth adapter and under that device on my phone, I can choose either to keep the phone feature active and/or the media player active. I can disable the phone feature and then only the media player will play through my speakers and I can take phone calls on the handset.
I have a galaxy S4 and I tried setting one to media and one to phone and it works until I shut off the car and restart then the Gogroove takes over both again, then the BT int he car kicks in and says paired but won't work again unless I re-pair it. Maybe its the Gogroove device so I'll try another one.
CG lover
01-26-07 10:28 AM
