Need to buy a new Battery....any suggestions?
#31
kind of a waste as when I unhooked my secondary battery the dead new battery lost the memories anyway
#33
Another vote for AGM battery.
#34
AGM batteries do have significant advantages over flooded lead acid technology.
But they are best used in applications where they are located away from engine heat (under rear seat or in trunk), and as such are not a good fit for the SC430.
#35
The pep boys web site on the Agm batteries makes no mention of any heating issues and carries a full line of models to fit every car made.
my die hard gold battery in my truck I think is Agm also and does have a factory heat blanket on it from Ford so they extreme heating may well affect these long term. My last Agm diehard lasted 7 years and my truck is used in the desert southwest in summer and has stainless steel header tubes in the engine compartment to add to the areas heating. No issues.
my Rv has thee Agm engine start batteries and the average life among our large group is around ten years.
located in the engine compartment adjacent to the 2000 pound engine, at almost ground level. Road heating from desert summer use has not affected any of our multiple thousand users batteries over the 30 years the coach builder has been installing them that anyone has noted.
Not that you are not correct technically but in actual use no issues
the mk web site who is the east penn disributor mentions -40 to plus 140 as the fully charged operating parameters.
east penn changed their internal plate mounting system four years ago to prevent plate warping and the shorting out of a cell from heat and projects a doubling of the batteries life because of it and a pre charge and testing of the plates before installation.
the higher cca and the 80% DOD available versus the 50% of a flooded cell and the ability to take a discharge without shortening the batteries life If deeply cycled like in storage to me out weigh the possible heating issues.
may call the mk engineer just to ask but pep boys and die hard by Johnson controls are both Agm to my knowledge.
interesting point. If I knew that the Agm would only last three years which is the warranty I would still use it for the noted advantages
the battery blanket in my 2000 Ford super duty was oem in August 1999 when the truck was made and was a flooded cell battery when new.
we will see as I am a keeper,
#36
I just checked my record. My AGM battery (now discontinued Sears Platinum) was bought in Nov 2011. Still working great in our Land Cruiser. It was $200 - worth every penny.
#37
But this abstract indicates just the opposite so I must stand corrected.
http://adsabs.harvard.edu/abs/2009JPS...190..162A
#38
I have been under the impression that AGM batteries were touchy in high-heat applications.
#39
While looking through a Lexus online parts manual I came upon a "Battery Box". It looked like just a big plastic covered box to conceal the battery itself.
The list price was somewhere around $200. I just wondering if anyone has one of these installed, or maybe I'm the only guy who doesn't have one.
#40
#41
#43
#44
and consider that the two parts comprise the "box" you are getting pretty close to $200.00. I'm not
sure I could find the parts site again where I first saw it listed as a single item. Anyway, just wondering if these were
stock, part of an option package, or available only on certain editions. I've never seen one installed.
#45
yes. I'm an Rv guy and batteries are super important in use.
its branded as their premium Bosch line. With a on line coupon it was $160?.
Measures out at 850 CCA. It is not an exact fit for the holddown plate to fit the batteries top shape but it works fine,
AGM is a much superior technology.
The holddown fits slabted a bit but tightena fine.
