Shop broke off O2 sensor; wants $2000 to Fix
So I dropped my SC off to get the front two O2 sensors replaced. Anyways they forced one off and the threads are stuck in the manifold and it needs to be retapped. The shop claims this is unfortunate but that it is not their fault because "this happens".....
This is a small time repair shop so I don't really want them working on the engine, when they couldn't get the O2 sensor right....
Thoughts on what I should do? I will have to have the car towed otherwise.
They claim 14 hours to remove and replace the passenger side manifold.....at $110 per hour (LOL)
Former Sponsor
Get the car out of there
the prices are insane
their claimed timing is insane
and the fact that they broke something while doing a repair and are not admitting is a huge red flag
Former Sponsor
this is a tough one then
I do all the work on my cars only time any car has been touched by another hand was when my wheel techs helped me swap new wheels
"This happens" isn't a valid excuse unless it was explained IN WRITING BEFORE the work began that it could happen and additional costs would be incurred.
So if you were not so informed before the work began, call a lawyer...ANY repair shop who breaks something while working on it should be held responsible for all repairs incurred to fix all broken parts. Or if available in your area file a claim in small claims court.
My mechanic somehow broke a TPM sensor when installing it in a new wheel. He replaced the sensor on his dime, but at the time could not calibrate it. He had me go to the local Lexus dealer to have that done and bring him the receipt at which time he immediately wrote me a check to cover the cost.
It's not the shop's fault or due to their negligence. They had no way of knowing before hand that the sensor threads were "welded" to the manifold. It probably became "welded" over time because of either corrosion or heat. Anyone who would have tried to remove that sensor would have had the same results.
Does any one know if when replacing o2 sensor do you use anti seize compound on the threads. If so why does the factory not use it. O2 sensors do have to be replaced from time to time. Would make sense to have a solution for a stuck sensor or a procedure
Location: Formerly Easton, Pa. Bradenton FL, now Osprey Fl.
What are these people replacing? Can't the old one be cut or ground off, then have a new fitting welded on to the pipe? Where the old one was taken off. At $110. an hour they sound like they want to become a stealer ship. I haven't been to a Lexus dealer in quite, I didn't think even they didn't charge that much an hour. To bad the mechanic that is doing the work isn't getting any here near that per hour. I really don't know why you would need a new exhaust manifold. Maybe try used?
Should one sign when having spark plugs replaced? Should one sign when having an alternator replaced? The same potential exists for damage when unscrewing anything.
Perhaps it's my background that I feel this way. In my younger days I turned wrenches on everything from B-52 bombers to my personal airplanes. There is always risk of parts snapping off after being exposed to elements for years.
If there was negligence on the part of the mechanic that caused damage, then I agree that the shop should be held responsible. I don't believe that there was negligence in this situation. "Stuff does happen"
You get an estimate of costs, meaning the risk of unforeseen problems is still on the customer. Technically it would be possible to enter into a flat fee contract where the shop assumed the risk of unforeseen problems but (1) no shop would do that; and (2) if they did, they would have to charge accordingly.
Having said that, I feel your pain. That's a big cost for something that isn't going to improve your enjoyment of the car.
I had my O2 sensors replaced at Merchants a few years ago. They warned me ahead of time that sometimes O2 sensors get stuck, and in that case I would need an entire new manifold which would be big bucks. Fortunately they got the snesors of fine and all went well.
In your case, if the manifold needs replacement, why not just get performance headers since you are already replacing the manifold anyways? Then at least you would get something cool from the repair and I'd imagine it would cost the same as OE?
I'd do the OBX ones but no reviews and concerns over issues later on. $875 is too much for the PPEs (versus retaping the existing manifold). BTW, my car only has 50k miles (2002 NM edition).
A clean, 2002 NM edition with 50k miles. NICE. I would leave it stock rather than do aftermarket headers.
