Propper procedure for jacking up vehicle and using jack stands
I'm looking for the correct procedure to jack up my sc and transfer to jack stands. I searched for this in the forum, but I'm afraid I could not find what I needed.
Specifically, when you use the jack points as directed in the owners manual, how do you use the jack stands? That is, if I am using my jack on the jack point location, where do I put the jack stands?
Can I just put the jack stands a couple inches from the recommended location and lower my jack to replace by jack stands? Since the recommended jack points are occupied by the jack, where do I put the jack stands?
I appreciate your help!!
I appreciate your help!!![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
First set the parking brake and or chock the vehicle. In the front I position the floor jack underneath the central cross member. It is safe to jack the vehicle up using this point. (Make sure you are squarely underneath the cross member and not the oil pan or anything else of consequence.). I then position jacks on either side of the vehicle using the recommended jack points or the vehicle's frame rails. (This prevents possible folding over of the pinch welds). Lower the vehicle slowly onto the jack stands. Check vehicle stability on jack stands before removing the floor jack completely. This way if the vehicle is unstable and slips off one of the jack stands by accident it will only drop one quarter of an inch onto the floor jack.
I then position the floor jack underneath the rear diff. (Also a recommended jack point). After lifting the rear of the vehicle to the same height as the front, I position 2 more jack stands at the recommended locations for the rear and lower the vehicle slowly and safely down. Make sure to check that the SC430 rests firmly upon the jack stands before going underneath to service the vehicle. A few shoves in both locations will help to verify this. Again, keep the floor jack underneath the rear diff. for safety when checking for any movement at the rear of the SC430... When servicing is complete, reverse the process.
This process has worked well for me in the past. I'm sure other members may have their own approach. Feel free to enlighten us if you have a better method. (Aside from a commercial hoist of course...)
![CircleL](https://www.clublexus.com/forums/images/smilies/498pxlexusdivisionemble.png)
![Agreed](https://www.clublexus.com/forums/images/smilies/boink.gif)
Dear LexEffect, thank you for the excellent response.
Could you please clarrify the statement "you can either go a couple of inches to the side of the recommended jack locations and do each corner individually, or more simply, jack up the front half using the central cross member underneath the front of the car and then jack up the rear of the car from underneath the rear diff. case.".
Are you saying that it is ok I used my jack stand a couple inches away from the reccomended jack point? And where is the "central cross member"? I didn't see reference to that in the owners manual.
Thank you very much for your help!!
Lexeffect,
Thank you for the useful picture and description. As a sidenote question, is that the drain oil plug in the diagram just to the left/northwest of the green arrow about 1 inch? I have been searching for a diagram of the drain plug location to no avail. By the way, the underside of your car is beautiful and especially those red sway bars!!
Lexeffect,
Hey! That's my car!!! Glad my pics can serve multiple functions for the member of this forum! That's the TRUE ClubLexus moral! Helping each other to make the most of our machines! The Pursuit of Perfection! Booyah!!!
Ps. I'm pretty perturbed that the Wiki Lexus page doesn't have a photo of the SC430. http://en.wikipedia.org/wiki/Lexus.
Additionally, I believe the page to have an error stating that 2001 was the first model....
Ps. I'm pretty perturbed that the Wiki Lexus page doesn't have a photo of the SC430. Lexus - Wikipedia, the free encyclopedia.
Hi,
I am new to the Lexus Sc430 having just brought one (amazing car!) and want to do some work on the brakes.
You mentioned that for jacking at the rear, to use the rear diff. To be honest, I have no idea what that is! Do you have a similar picture or diagram highlighting where this is or what it looks like?
Thanks!
Luke
Thanks!
Luke
The rear differential or also known as the rear axel.
Please be very careful and have someone help you, always use jack stands. If you do not, the jack could fail and the car could fall on you and That would not be cool.
SAFETY First!
The owners manual may show jacking points.
SAFETY First!
+1
Raise the car with a floor jack using the differential for the rear and the sub frame in the front.
Place your jack stands only on a firm surface. Important: Use the same locations on the frame to place your jack stands as those indicated in the manual for using the scissor jack provided for changing a tire. If you choose to place the jack or a jack stand on the wrong point on the suspension a component can easily be bent and ruined (the same reason separate reinforced flat bed tie-down loops are provided - to prevent straps from being used across suspension components).
Ideally use jack stands in pairs, either two or four and use wheel chocks to prevent the car from rocking on the jack stands.
In addition to jack stands and wheel chocks, as a final safety measure, if your repair includes any aggressive pushing or pulling that might rock the car, remove a wheel and slide it under the edge of the frame in the corner where you are working to guarantee the car can't fall all the way to the floor and crush you.
