Roof opens only intermittently
SC07, not to be a jerk, but we get asked this question a lot. The answer always starts with the same statement. You need to go to the dealer to get the convertible top error codes or buy a copy of Techstream off of ebay (for about $25) and put it on an old computer. https://www.ebay.com/sch/i.html?_fro...tream&_sacat=0
I think it is the pulse width modulation in your motor, but without the code, we can't really tell you for sure. Once you get a code, we can help you solve the problem
Since our cars are older, the version shouldn't make much difference. Read this post for more info https://www.clublexus.com/forums/sc4...solutions.html
Be aware. The Techstream software will only work with window XP (32 bit) If you have newer Window version i.e Window 10, you need to buy Techstream version 10 or higher. Even then, you need to modify your Registry for it to work. It’s complicated unless you’re computer whiz.
What you should do is buy the cable and software and ask the seller help you to install via TeamViewer.
Just curious if you ever upgraded to this version...I haven’t because I am okay with the way mine is operating...this version looks really easy to load...and I agree XP 32bit is the easiest.
https://drive.google.com/drive/mobil...3M?usp=sharing
So Techstream does work with Win 10.
I’m back to report that the code shows: B2523 Limit switch (Roof position No.1) malfunction.
As far as the research goes, roof position switch No.1 & No.2 are integrated into a single part, the part number is 84742-24050. And my car is 2007. Can anyone confirm if this is the correct part before I place the order? Thanks.
It looks like it is the switch near the visor area. In the past, people have had problems when something got caught in that area. Things like tape that inadvertently got placed in that area.
When I had a problem with my roof, BGW70 or VVTIBOB was nice enough to make a copy of that section from their factory repair manual.
I would hold off buying anything, until you can get your hands on that section of the manual. $81 bucks is a lot to gamble.
I am not familiar enough to tell you what the code means. I did google the part number you gave me and came up with this diagram
thanks DD, but it’s not the part shown in this diagram. The switch is at the rear of the car,upper right side of the trunk, a owner from Japan posted a thread with pictures on how he fixed his.
But then again, there is a good chance the switches are all the same.
His post is on this forum, and actually on his post he borrowed your pictures of trim pieces taken off the trunk
Update: fixed the problem through team work between a good friend at Toyota who kindly helped with tech stream, got the code B2523. And charismatic neighbour who happens to have extensive connection among dealership, sourced me the part and got it installed at Lexus.
Thanks PO Dan for replying my private message, and thanks all for contributing
