brake fluid color
Do a drain and fill. Means suck up the old fluid and replace. Or else do a purge. Good luck.
That's one thing I noticed all SC430's tend to have, very dark color in the brake fluid reservoir. Must be a common thing. Get yourself a turkey baster type suction thing, and replace all you can... especially during a brake job, after you are compressing the pistons in on the calipers to insert the new meatier pads.
The SC430 has a unique procedure to follow to flush the brake fluid. I did follow it to a "T" when I flushed ours, but I did find the correct info here, and I don't remember the exact procedure. Do a good search and you should find it posted somewhere here. Just remember, flushing the brake fluid does not follow the normal sequence of events.
ToyotaLexus
Suspension and Brakes
02-16-09 07:46 PM
