Lowering the ride
Old 08-17-14, 08:48 PM
DarthSid
DarthSid's Avatar
Originally Posted by djsurfer
No I dont believe so, Im on Weds Kranze Bazreias and never needed then on my LS400...
I recommend you check your front rims to verify if the hub centric ring is missing. Most after market wheels are manufactured with a much larger hub opening greater than 60.06 (or 60.1 round up) millimeters to allow fitment on a variety of vehicles. If the centric ring is missing, than the rim is relying on the lugs for perfect centering or lugcentric, which leads to vibration of the wheels and steering wheel. This gives the driver the sensation of an unbalanced tire. Both the LS & SC have the same hub diameter of 60.1mm. It couldn't hurt to check, as I've been down this path.
Old 08-17-14, 08:49 PM
texsexlex
texsexlex's Avatar
Originally Posted by Acura2Lex
What are your wheels offsets and widths? Also what tires are you running? I'm thinking of maybe going to an 18 inch setup.. Yours is looking good
Sick.
...thanx for the compliment, loving your wheels also !!! I'm running Stern ST-2 wheels....fronts are 18x8.5 w/20 offset & rears are 18x9.5 w/25 offset...you could do a 10in in the rear, with the same offset & have no issues. The tires are Michelin Sports A/S Plus.....225/40/18 front & 275/35/18 rear...Michelin has the A/S 3 now, which has replaced the tire I'm running
...a little blurry, but this is my set-up with the new body kit
Old 08-17-14, 09:14 PM
djsurfer
djsurfer's Avatar
Hmmm never thought of that. Im gonna check that out tommorow.
Old 08-17-14, 11:43 PM
Acura2Lex
Acura2Lex's Avatar
Nice specs bro.
Old 08-18-14, 08:36 AM
FrictionSc
FrictionSc's Avatar
Had this same issue last week. Put hub ring and issue fix.
Old 08-18-14, 08:47 AM
djsurfer
djsurfer's Avatar
What brand and where did you buy them? I dont like to cheap out on anything so Id like to get the best unless all the aluminum ones are seeying are the same.
damon
05-24-17 02:28 PM
Toxicxk23
Suspension and Brakes
17
06-23-12 06:34 PM
swegs430
12-11-10 12:11 PM
Smooth1
05-07-06 01:06 PM
Quick Reply: Lowering the ride
