PCV Valve Location/Replacement/Seafoam?
Hi All-
I read that it is important to check, clean, or replace the PCV valve. Does anyone know the exact location of the PCV Valve and have a picture? What is the proceedure for replacing?
Also, I recall that the fuel injectors can be clean be slowly pouring Seafoam through the PCV valve? Is that correct? Has anyone done that before?
Thanks!
Thanks!
