SC 430 Low Beam Headlamps Short?
I just pulled the bumper to fix an issue with the driver side low beam headlamp. After running for a few minutes the driver side light would go out. Now that I have replaced both bulbs and put it all back together, both lights are having the same issue! The driver side goes dark after about 3 minutes, then the passenger side does the same thing about 5 seconds later? There are no other issues with any of the lights and the bulbs clearly are good. If I turn all of the lamps off and turn them back on, they repeat the same issue in the same order. Could this be a relay issue? I am sure I have all the proper connections made and am dumb founded. Any suggestions? Will a scan from Autozone pick up on any codes for this? Thanks in advance.
Sounds like a driver or something is overheating.
