Open/Close Roof Switch will not even blink
#31
Can you post the parts that you purchased?
Pvong713,
Well I have made progress. As I suspected my package tray was not fully closed. As a result the ECU received mixed signals and just closed out the opening closing command. No response from main switch on climate control, No light.
I manually opened the roof, and cycled manually opening and closing of package tray several times. It seated flat, closed the roof, and removed the battery to clear any codes.
Went to open the roof and everything worked as usual. was able to cycle it twice before the package tray refused to open.
So i am going to order both package tray limit switches and the electric motor. Solution!
I advise you to manually cycle the top open and close before taking it to the dealer. my guess is you as well have mixed signals to the ECU and your simply being locked out. Hope this helps and best of luck..
booker247 (06-11-20)
#33
Yah that's one of the first things I've checked. I might try to reset my ecu. I read in a different forum that you have to disconnect the battery for an 1hr to reset the rooftop? Never heard of that before but might try it. Crossing fingers
#35
hey bro...i had the same problem as you just right now.....the guy 2002430SC right under this comment had the solution the whole time...... i opened my glove box....hit the trunk button open a few times......then put the key in the ignition, press the close button and everything worked normal....i never disconnected batteries or any of that stuff.....
i just read your comments, other replies until i got to 2002430SC......it was easy.... 1) glove box 2) hit the button a few times, who cares how many 3) key in car, 4) press open/close....
you'll get full function of your hardtop and indicator lights will come on..
i had the same exact problem as you.....except mine was down when it happened and I needed to close it.
#36
this worked! easy.... took 1 min...
#37
Paul
