your valued opinion
On an 06 things to check yourself,
trunk struts _ do they hold the trunk up at all angles. Open trunk 1-2 feet , let it go and it should not close
Door speakers - listen to carefully to them. That's about the age where the foam degrades and they can start to sound raspy.
Foggyness, scratches or distortion on the climate control plastic glass, anti glare scratched
Headlamps - did someone hit it with a buffer while trying to buff the car?
Headlamps - when starting car they should reaim by moving down then up.
Get at least 2 master keys. If you only get one its expensive to reprogram a 2nd key.
Good luck. It's a beautifull car.
