50K miles, 12 yr old=when to change timing belt?
Old 11-01-14, 05:44 AM
Buggeroff6
Buggeroff6's Avatar
Default 50K miles, 12 yr old=when to change timing belt?
First off, why did Lexus choose a timing belt that can hurt the engine if it breaks? I got this car 3 mos back and all records show they never had h20pump, timing belt replaced. Is there other stuff to replace, or can I skip serpentine etc b/c of rel. low mi.?
BTW, any underdrive pulleys out there? Would this be time to change em? I don't think there's much advantage to them, right?
Some people on here say Toyota can do the work-cheaper than Lexus 1,200USD...would I be running risks even if they have same engine in someof their cars?
Old 11-01-14, 06:36 AM
bacardi11
bacardi11's Avatar
Toyota will do it cheaper have them do it. I replaced mine at 73000 was like new + water pump + other things. we just replaced my sisters Honda belt at 140,000 + pump looked new.
Old 11-01-14, 12:53 PM
sorka
sorka's Avatar
It's not the timing belt. It's the head design, valve time, and piston design that results in "interference" engine. Most engines these days are like that due to their higher compression ratio that brings piston closer to the top of the head. More often found on engines that take premium fuel because of their higher compression ratio and more advanced timing. The result is better performance.
12 years old is way past due. Change it now.
Old 11-02-14, 02:33 PM
DarthSid
DarthSid's Avatar
As a Lexus mechanic explained to me it's either age or miles. At 24,500 miles and at 12 years old when the timing belt was inspected there was slight cracking on the belt. The idlle pully was starting to show some wear. I was very happy I had the service performed. My car now runs like news.
Old 11-04-14, 05:17 PM
SlvBullet
SlvBullet's Avatar
The belt manufactures say change rubber composite belts at about 8 yr so you're over due. Do the entire 90k service and you wont regret it.you ight want to change the plugs too - easy enough DIY and I fledt a great improvement.
mulasien
04-29-20 10:10 AM
flyboyplo
03-31-13 09:14 AM
BillCarson
22
03-03-12 12:46 PM
dude74
14
04-01-02 10:29 PM
Quick Reply: 50K miles, 12 yr old=when to change timing belt?
