Hesitation, throttle down-blip, lurching, cut-out - need diagnosis help please!
#33
what is a "throttle body sensor"?
throttle position sensor?
Have a link or photo to show?
I have same issue got a Throttle motor code but didn't get a chance to write it down before the mechanic cleared it and it never came back but the car is running lean and stumbling.
Thanks
Thanks
As for my issue, yep, throttle position sensor. It's located on the driver side of the throttle body/air intake under the decorative engine cowling. You'll have to remove some vacuum hoses to get to it and I would recommend a very short Phillips screwdriver for removing the two mounting screws. If you choose to install a new one, put the sensor on with the electrical contacts facing upward at about a 20-30 degree angle and then rotate counterclockwise until it's back in position (contacts should be about horizontal or pointing down slightly). The non-technical way to adjust it is to turn on the engine (don't touch the accelerator pedal) rotate the sensor until warm idle is about 600-700rpm, then fully tighten down the mounting screws. Make sure to put all of the vacuum hoses back on!!
#34
Just hit 42k miles. I just had my oil changed and while in the shop I had my mechanic do a Seaform flush through the PCV valve. While we were letting the Seaform soak in, we also cleaned the MAF and the Throttle body plate and intake. On start up and initial test drive, the car was puffing huge amount of white smoke and the acceleration was gone (no combustion). No CELs. But within about 15 minutes, the car returned to normal, white smoke stopped, and I could feel the car picking up power. Also saw my MPG's increase about 3 MPG's over what it was previously (city driving). All in all with the oil change, Seafoam treatment, throttle body cleaning, and a windshield wiper hose repair, ran me $100.
#36
If you run 1/3 can of Seafoam through the PCV valve it will really sharpen acceleration. Just be prepared for a giant bloom if smoke coming out of the exhaust. The manufacturers says that this is just steam.
Cp2295
11-26-16 12:24 AM
Cure
Performance & Maintenance
08-08-14 09:04 AM
Suneet
12
06-07-07 11:33 PM
