Perhaps the most ugly cold air intake ever made?
Old 01-05-15, 07:09 PM
  #46
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,271 Likes on 1,378 Posts
Originally Posted by LexBrett
Yes I am in Nova. Is SRT able to tune my vehicle? Did you have that done? How much did it cost and what was the result? I ask because it was my understanding that the ecu on this car could not be tuned? Thanks!
They used to; they dyno tuned my old GS in the past using this method but was 10+ years ago so you should give them a call.
They are not tuning the OEM ecu, they are tuning the piggyback ecu that does the air fuel mix
Originally Posted by bacardi11
dave
when you add headers the engine become leaner more at the top end. the only way to add fuel you must increase injector size. its like jet in a carb you must add fuel by upping the carb jets there is no other way.and with injector you must upgrade the injector size.
when you lean a engine you must add fuel. that's why they have people that do injector work.
Understand and I swapped injectors and high flow fuel pump when they installed my supercharger and tuned. However there is still a good bit of tolerance even with headers from what I've seen of Lexus AF safety margin to eek some more power even with factory fuel. Each car is different though.
Old 01-05-15, 07:19 PM
  #47
bacardi11
bacardi11's Avatar
dave
so you know what i'm talking about. if a engine runs lean at the top end what happens. yes I understand and i'm glad you know what i'm talking about.
Old 01-06-15, 07:41 AM
  #48
bacardi11
bacardi11's Avatar
there are shops you can send the stock injectors to be reworked if doing any kind of racing or street performance cars and still be stock. I see a lot of guys want more performance but it must be done right. if you add more air and exhaust system, headers ect. reworked injectors is a very safe bet for performance. reworking injectors mean its on the money. then you need to know if the fuel pump will work properly pumping.. now you have a nice setup air, fuel, and exhaust. now gears the Supra rear is the best setup so far. the 4.10. gears are to much. 3.90 maybe.
to me what I been talking about would be the best setup for 430sc and be stock.
Old 01-06-15, 06:56 PM
  #49
mandyfig
mandyfig's Avatar
Whew, the stuff flying over my head. I like and love my SC as it is.
edmondt
06-21-18 05:39 PM
MWIS350
03-07-16 08:41 PM
Shep34205
Performance & Maintenance
03-28-08 07:14 PM
KrazeMatik
05-01-05 01:00 AM
MadMaxSC400
13
11-29-01 11:34 AM
Quick Reply: Perhaps the most ugly cold air intake ever made?
