Moog end link advice
Recently I installed Moog end links in the front. Now I am getting "clanking" noises from the new end links.
A quick search on CL showed that others have also had this problem. One remedy some have used is overtightening the links.
Does anyone have experience with end links making noise? Is this just a making of additional torque needed? Should I go back to oem?
So I may have figure out the phantom noises coming from my end links. I called the tech support for moog, and they said if my guy at merchants used an impact wrench to install the end links they would become damaged..
There are still good mechanics out there but many times they are pressured to produce more units vs. producing quality units.
In your case, I hope you are not in a situation where something is ready to actually separate.
If they are a reputable place, they will own up to the error and not charge you for the replacement parts and labor.
I am not sure if this is the store you use but you may want to read this about Merchants.
http://www.consumeraffairs.com/autom...tire_auto.html
Here is a comment that is close to home for you:
This entire corporation is out of touch with reality. They hire incompetent people for safety related repairs. Once I left with my 30 years of experience they had two "technicians" left with a combined 1 year experience. These are the people taking your life into their hands when replacing a tie rod or ball joint. I have sent multiple emails to the TBC Corporation regarding this matter with no response. An engine blowing up is one thing, however replacing steering and suspension components is something else… Always check out any "technician" working on your vehicle.
5% Club. Killing it!!!
Not sure if you a garage or not but most suspension parts replacements you can do yourself if you have the proper tools... End links, tie rods, ball joints, UCA, and S/S can be done by you or with a buddy... I've done a few things but other areas i will not touch and the SC430 and 2Gen GS models resemble each other closely in the suspension area..
Its hard to swallow when mechanics are charging $100hr for half a$$ work that is rushed and could cause problems down the road...
And when I do find a missing bolt, I can only laugh at myself!
I knew very little about cars until the age of 23, then I began to go to the library (before youtube) and read, go home and practice on my beaters, finally rebuilt my 1969 ford Torino GT, BB 390cu and just went from there. 27yrs later...it is still fun!
I must say Toyotas and Hondas are built very well and in most cases very easy to work on! IMO
If that was directed at me, I agree with you 100%. I sit at a desk all week but get my hands dirty on the weekends. I love working on cars, I enjoy the satisfaction of driving the vehicle after my work and knowing the work was performed correctly.
some these guys can do complete engine swaps in there garage without thinking twice.... i wish i could do that....
Really?? Did you install them yourself? What what the torque spec? 30-35 pounds? I don't know whether the links are defective, over torqued, under torqued, or the sound is something else.
I have read on CL that others have had this problem with clunking noises with moog..
But the sound is coming right from the end link area and I have had two guys look at it and everything seems tight.
So frustrating..
So frustrating..
LexBrett, any updates on your situation?
I'm going to install the darn end links myself with the exact correct torque and will take back the defective links. Haven't gotten to it yet, maybe this weekend if weather and time permit. Will let you all know!!
