Rear emblem removal and replacement
Old 02-14-15, 11:38 AM
caesar400
caesar400's Avatar
Smile Rear emblem removal and replacement
I am going to replace my rear Lexus emblem. I tried using dental floss and goo be gone, but had no success. Does anyone have any suggestions?? Also, the new one I have didn't come with any adhesive. What is the best thing to use, or does it stay in place with the two plastic pieces sticking out of the back of it??
Thanks-
Lisa
Old 02-14-15, 07:35 PM
Bon
Bon's Avatar
The two plastic posts poke through the sheet metal and have push-on fasteners on the back side. You have to remove at least some of the inner trunk liner to get to them.
Old 02-17-15, 03:59 AM
Caseoane
Caseoane's Avatar
Heat it up. Use a blow drier for a while and it'll come off much easier...
Old 02-17-15, 04:28 PM
NovaRnder
NovaRnder's Avatar
I took off the Lexus and SC430 on both ends. Yep, you need to heat up the emblem to make it workable, I used my wife's little hair dryer. Also instead of using dental floss the whole way, I found it easier to use the floss only to start it then I use a string (fishing line or wool strings) to get a better pull. The Goo Gone works wonder to take off the adhesive residue left on the vehicle, just be patient with it and take your time.
yOyOYoo
06-15-20 02:38 PM
poweredbyg
07-01-15 08:22 AM
istundra
05-02-07 08:24 PM
lexus4jess
05-19-06 01:01 PM
bill davis
03-19-06 10:23 AM
Quick Reply: Rear emblem removal and replacement
