For those of you with leaky trunk syndrome
Pure genius!
My sc had some leaks around the gasket area and it would eventually run down along the sides inside the trunk into the area close to the gps unit (see picture). I did some testing and found that the little drainage holes were not blocked and that it was probably due to worn out gasket. I took it to Lexus and quoted me almost 1000 dollars to replace the parts
Here’s the part# for the weather strip.
1.) 63252-24030 $199.08
2.) 64462-24010 $246.31
Plus 4 - 5 hours of labour at 140 dollars per hour "
I ended up in homedepot buying this stuff : http://www.homedepot.ca/product/sili...t-black/864990 and just taping it to top of the trunk rubber. Used some rubbing alcohol to clean up the existing rubber and just taped it with the skinny side against the edge of the trunk lip. I then used some silicone epoxy and sealed the few edges of loose rubber gasket against the rear window glass and 24 hours later no more leakage. We had very heavy showers last night and i left it outside to soak for almost 5 hours. Upon inspection the trunk area was bone dry.
Give it a try, cost about 30 dollars for the silicone and the weather stripping. Easy to do and quite effective. Plus it doesn't interfere with the top operation and the black weather stripping looks very OEM.
All the clear white stuff is the dried silicone. Totally worth it. Basically the same stuff as the bathroom caulking but for automotive purposes. With the naked eye you can't even see it. The new silicone weather stripping is tight around the portion before the rear window to ensure a good seal
Kinda hard to see but it's black and I just tapes it along the leading edge with the skinny part towards the outside
It's a good seal
Added some silicone along the bottom side where you can see the shinny reflection. The yellow stuff is some jb weld the owner before put in. Really nasty stuff and I'm trying to get rid of it
It's a good seal
FYI - I had a leaky trunk at some point (not sure when, probably before I bought it)... killed my navigation system... Around $2500 repair. I filed a car insurance claim - comprehensive. My company paid! Worth a try if you need that repair!
JohnnyCake
04-25-13 04:39 AM
