Radio antenna connector sizes
Old 04-15-15, 01:07 PM
theazz
theazz's Avatar
Default Radio antenna connector sizes
SC430 has 2 different size radio antenna plugs (1 for windshield and 1 for rear telescoping antenna) that plug into the back of the existing radio. The telescoping antenna is a standard Motorola plug size but does anyone know the size of the smaller one so I can adapt a y connector to plug into my new pioneer head unit (it only has one antenna input) in order to utilize both antennas on the car. I've checked around at various stores and no one has a clue of what I'm talking about.
Thanks
theazz
Old 04-15-15, 04:59 PM
ShawnOk
ShawnOk's Avatar
I modified both antenna inputs behind the radio so I can switch primary and secondary antennae inputs (ie. windshield is my main antenna now). The smaller one is actually a proprietary Lexus antenna, BUT you can check out Fry's Electronics or local car stereo shops. I found what I needed at both. Fry's carried an adapter to allow me to turn the smaller type to the larger Motorola type. The shop had the other adapter to allow the larger Motorola type to the smaller type but had "modify" it by sanding down the edges of the smaller one to fit the smaller input on the back of the radio for me.
Old 04-16-15, 05:22 AM
theazz
theazz's Avatar
Thanks Shawn I'll look at Frys.
Theazz
Old 04-16-15, 04:38 PM
Harold57
Harold57's Avatar
Can you post a picture of the two? I might can identify it from that.
Old 04-17-15, 07:21 AM
theazz
theazz's Avatar
Here is a picture of the back of the oem radio antenna inputs. I already have the new radio installed (only using the larger antenna plug right now).
theazz
joemg (05-08-23)
Old 04-17-15, 02:47 PM
ShawnOk
ShawnOk's Avatar
TheAzz, they also sell a "Y"Motorola Plug that would allow you to combine both antenna feeds. But of course, you'd still have to fine a small to large adapter before that.
Old 04-18-15, 05:09 PM
Harold57
Harold57's Avatar
Sorry, I don't recognize the 2nd connector after all. Bummer. Take the picture with you when you go "shopping" at Fry's or Radio Shack. (I'll keep my eyes open until then though.)
Old 04-19-15, 04:17 AM
theazz
theazz's Avatar
Thanks for your help. I'm calling metra tomorrow. I think they might be able to help.
Worse case is I cut off the smaller connector and put on the larger one and then do a Y. Radio Shack was a bust
Theazz
Old 05-07-15, 03:21 PM
Bgw70
Bgw70's Avatar
theazz
Did Metra have the correct cable to combine these two?
I know the larger is the standard Motorola size male plug found on the majority of cars. Does anyone know the proper name for the smaller plug? I will call it Lexus for now.
Does anyone know that the other end of the male Lexus cable looks like? If it is a regular push on type plug found in most other places in the car then I do believe Metra may have a replacement cable that would have the larger Motorola male plug.
Then all you would need is a male Motorola to a Y connector with two female Motorola plugs.
Old 05-11-15, 05:28 AM
theazz
theazz's Avatar
Metra did not have the adapter and said they couldn't help (bummer).
Old 05-11-15, 10:55 AM
ShawnOk
ShawnOk's Avatar
Try a local audio shop or even a shop that specializes in cb radios. I found mine locally at a shop and at Fry's electronics .
Old 02-24-16, 07:09 PM
Bgw70
Bgw70's Avatar
Does anyone think this will fit our Diversity antenna connectors?
http://www.walmart.com/ip/10756081
Old 10-28-19, 01:16 AM
KahnBB6
KahnBB6's Avatar
Received 1,237 Likes on 864 Posts
theazz
Bringing this thread back to note from some research I have been doing into this same dilemma with my 1993 SC300 since the same diversity antenna connection arrangement was used on many Lexus models.
According to this thread...
http://tlcfaq.com/main/2012/05/land-...stereo-wiring/
...the smaller of the two antenna connectors can be adapted with a Scosche MDA-B Micro/Delco Antenna Adapter Tip and a Metra 40-UV43 Motorola Antenna Y-Adapter.
Hope this helps someone who still wants to retain the use of both their factory antennas even though an aftermarket stereo will not provide the dynamic diversity switching function.
joemg (05-08-23)
cep89
GX - 1st Gen (2003-2009)
10-16-21 07:34 AM
Oldsports
10-05-18 05:18 AM
HDH
03-12-18 07:49 AM
boxcarfan
GS - 1st Gen (1993-1997)
08-19-10 09:51 AM
Lexson
SC- 1st Gen (1992-2000)
15
08-29-02 02:11 PM
Quick Reply: Radio antenna connector sizes
