Lexus Customize Function
So I finally found some time to review a pdf I found via another forum. Basically, it's the Lexus Customization Protocol. I was told that I could take this form into the Lexus Dealer and have my customizations altered. When I purchased my SC in 2002, I was never informed that I could change these options. Pretty interesting options. A few things really caught my eye. First thing I intend to change will be the alarm beep. I want to set it to MAX Loud. Second is the UNLOCK/PARK so the car will auto unlock on park. Next I will also change the AUTO LOCK when I hit a certain speed. Currently mine does not do this. I liked both of these features on my mom's 2015 Avalon. I'm also going to put the wipers into SPEED MODE, which and REWIPE SPEED MODE, so the wiper will autoadjust dependent on my speed of travel. Right now, my car doesn't do this. I noticed that I do not have a key buzzer, so I will request KEY BUZZER to be set to large. Lastly, and probably most importantly... I noticed that everyone complains about the hot air on their feet once the top is dropped. This can be turned off under FOOT AOUT OPER. I intend to turn it off. I never understood this feature. No matter what I previously set the temp before turning off the blower, it always blows hot air on my feet. Not my cup of tea. Going to disable it. Those are my requests for customization. Not sure how much this will cost me at Lexus, but hopefully not too bad.
Additionally, I did notice one thing for all those with CHECK ENGINE LIGHTS after adding exhaust work.... there is an option to reprogram the Emissions Gas Sensor (called GAS SENS SHIFT under point 11). This might be an option for those getting a CEL. It can be changed to Less Sensitive. Might be something to look into for those having problems!
PS. I also read that you can raise and lower the windows using the key in the driver side lock either toward or away from the engine for a delayed amount of time. I knew about holding the unlock button on the fob to drop windows but never knew about raising them from the door handle.
Awesome find! Thanks for the info Shawn. Let us know how much it cost to do this at the dealership
Hey Shawn, why don't you just order the techstream software with cable for $25 and do the programming your self?
I just did most of those settings on mine, yesterday!
PS I would rather go to Lexus here in shreveport. They treated me much better the second visit. Quoted me $80 on the phone to readjust my headlights. Charged me $65 including tax and went above and beyond to help me.
I Completely understand and if I was located closer, I would do it for you! I am in central Florida, east coast, near Melbourne.
My biggest issue with the techstream software was finding the correct driver for the cable, but all is working well now and I can program all functions on the car.
As for the VSC off light, i get that every time I access the OBDII connector. My simple fix is to short pins 4&14, when the VSC light flashes fast turn off the key and pull the wire.
BTW, this procedure came right out of the Lexus service manual.
My biggest irritation with the previous programming was when I put the car in park only the drivers door would unlock. Now both unlock.
Interesting you did yours yesterday! I just jumped through all the hoops last night to get it all working on my Win 7 64 bit laptop and just walked back in from playing around out in the carport with my SC. I ran tests and changed a couple of my C-BEST settings.
I did notice my VSC and ABS light were flashing but I just turned off the key and pulled the plug and when I turned the key back on the lights were out. Awesome little 25 dollar investment!!
Have you driven the car since you made the changes?
The VSC light goes out for me too, until I move the car...then it comes back on and I have to do the pin jumper, 4&14.
Lexus wanted $150 to do the programming...NEGATIVE!!!
Ok, you were right. As soon as I backed out of the garage the VSC light came on. I jumped pins 4 and 14 with a paperclip and the VSC light flashed real fast and I turned off the switch and pulled the jumper. Looks like it fixed it. Thanks!!
It is a great value! I installed mine on an old XP machine I still had...
Lexus wanted $150 to do the programming...NEGATIVE Blue Leader!!!
I think that's dependent on the year of your car - I never have that happen when I play with the settings on my '08. The software makes the changes and I'm good - no spurious lights.
The 2006-2010 use a different OBDII bus type and will not receive the VSC light when something is plugged into the OBDII connector.
It could just be something in the 2002.
Good info Jim! I am still trying to figure out if I am doing something wrong or not doing something before I disconnect the OBDII connector. This happens with the Tech Stream software and a hand held code reader.
Also, are you using one of the inexpensive cables?
If you suddenly have the "VSC TRAC" and "VSC OFF" lights in your dash, this post may help you fix the problem yourself. The information here applies to 4th gen 4Runners that use the ISO protocol rather than the newer CAN protocol for their OBDII interfaces to code readers, ECU programmers, hand-held testers, etc. The OBDII interface includes several different protocols (methods of digital communication) and they all use the same physical connector, though with some different pins. The connector is located at the bottom of the dash on the driver's side and in the 4Runner it's covered by a small black cap.
4Runners switched from ISO to CAN around 2005 though this information may also apply to newer 4Runners with some modification. That is, newer 4Runners may display trouble codes and reset sensor calibration values in response to the connection of different (than earlier 4Runners) pins together than the ones described below.
Several posters have discussed similar problems, described in several different threads. I'm reluctantly starting a new one, with a more specific title (including the exact name of the two trouble indicator lights), in the hope that searchers will more easily find a solution.
The specific behavior: On startup, the "VSC TRAC" and "VSC OFF" lights come on and stay on. The ABS light may or may not come on. On subsequent starts the lights will come on temporarily as usual (as a bulb check) and then go off. They come on again and stay on as soon as the 4Runner is moved. The "check engine" light does not come on. This behavior begins after the vehicle has been hooked to some sort of OBDII code reader or engine tester or data logger, etc. Though the lights are on, no standard OBDII problem codes are detected by a regular code reader.
Cause: The code reader or other OBDII device has attempted to communicate with the 4Runner using the CAN protocol (involving pin #14) and this has caused the 4Runner to erase the "zero point calibration" numbers in its memory. Without these numbers it can't get accurate information from the yaw rate and deceleration sensors (in the center console near the gearshift) and so it disables traction and stability control functions.
The fix: Perform the "zero point calibration" procedure as described in TSB BR001-04. This procedure can be performed without special equipment such as a hand-held tester or OBDII reader. You only need the equivalent of a jumper wire to short together two pins of the OBDII connector at the right time and the right number of times between switching the 4Runner on and off. More detail is included below, leveraged from my other posts.
Why this doesn't happen every time a code reader is used: The code readers usually use the pins and protocol of the OBDII connector in a specific sequence, trying first to establish communication with the vehicle using the oldest protocol. They then try the pins and protocol of newer protocol standards. Usually the code reader would be successful in its first try at establishing contact with the 4Runner using the ISO 9141-2 protocol, and there would be no problem. However these communications schemes are not foolproof and occasionally the ISO protocol attempt fails. Then the code reader tries newer protocols including CAN (controller area network). It's this CAN attempt, which toggles pin #14 (the CAN data pin) that accidentally tells the 4Runner to erase the existing zero point calibration data. Since the 4Runner (this vintage anyway) can't communicate by CAN protocol the tester re-tries the older protocols again and eventually succeeds in setting up communication by the right ISO protocol. But by then the calibration data has been erased.
The calibration, by the way, is simply a matter of telling the 4Runner VSC/TRAC computer "your yaw rate and deceleration rate are currently zero" and to save the associated values. Then the output from the sensors can be interpreted correctly.
Detail (may be helpful if you're going to do the calibration procedure yourself): The SST (special service tool #09843-18040) specified in the service manual appears to be essentially a Y-shaped test lead and is variously called a "jumper wire" or "diagnostic check wire." It's used in this case to repeatedly connect and disconnect the chassis ground (CG, pin #4) and Ts (pin #14) terminals of the OBDII connector (referred to as DLC3 in Toyota-speak). The connection/disconnection sequence and timing are described in the service manual and in several TSBs. OBDII connector diagram and pin descriptions are in TSB BR005-03.
Since the OBDII connector is at the lower edge of the dash and pointing down (right above your left foot when you're sitting in the driver's seat) it's rather tough to reach in and do the shorting to the appropriate terminals of the OBDII connector with a test lead. Especially since you're supposed to avoid moving or shaking the vehicle when you're doing this. BTW, the OBDII connector usually has a black snap-on cover over it to keep out grit, etc.
Therefore I took a couple of pieces of insulated wire about 24" long each and taped them alongside each other, and stripped both ends. To make the wire fit securely in the (female) terminals of the OBDII connector I soldered a 3/8" length of metal (cut from a heavy paper clip) to one end of each of the wires. I chose a pin size so that would fit securely in the female terminals of the OBDII connector but wouldn't distort them. I used some heat shrink tubing around the solder joint to reduce any chance of accidental shorting.
After plugging the two pins into the OBDII connector (with the other ends held apart) I was able to hold the other ends of the two wires in my hands and touch them together at the appropriate times to connect the pins of the OBDII connector. I had a helper in the passenger seat to read the instructions from the TSB to me in sequence.
This is not very hard to do, and one need only be careful. It's easier to do with the Toyota OBDII tester, of course, and would only take 5 minutes. You might be able to get your dealer to do it gratis, but you might also be charged some minimum labor hour rate.
BTW #1: Doing the sulfur TSB or others that require the replacement or reprogramming of the engine computer or the VSC computer will also require this calibration.
BTW #2: I verified that when the lights are on the VSC and traction control are indeed inoperative. ABS is working, though.
BTW #3: Shorting other pins (such as #13 Tc) at the right time can cause the appropriate dash indicators to blink in sequence to reveal trouble codes other than the OBDII ones. A generic OBDII code reader won't give you this data, and you need the service manual (physical or online) to make sense of it. I believe there is a specific code to tell you that the zero point calibration data has been lost, but I didn't look for it.
BTW #4: In the 4Runner of this vintage the OBDII connector pins populated are 4, 5, 7, 9, 13, 14, 15, 16
[Sorry about the long post, but I wanted to include the kind of information I'd want if I encountered this problem and wanted to feel comfortable fixing it myself]
I do think it's kind of funny with all the technology used to keep us safe and the cars operating correctly.....we need to keep a paper clip handy to fix it! Priceless. In the old days, the hero always saved the ship or train or plain with a safety pin. At least there's a way to us mortals to deal with the problem.
I do think it's kind of funny with all the technology used to keep us safe and the cars operating correctly.....we need to keep a paper clip handy to fix it! Priceless. In the old days, the hero always saved the ship or train or plaidn with a safety pin. At least there's a way to us mortals to deal with the problem.
