O2 sensor question
1-8 on the bottom row, or wider section of connector.
9-16 on the top roe, or narrower section of connector.
If you zoom in on this picture, you should be able to see the PIN numbers.
Short pins 4-14,
Turn on key, engine off
VSC light will flash fast
Turn off key
Pull wire
Start car and drive down the street, any lights?
When you look at the connector, the location of pin 1 is as follows, counting from the firewall side and top row is on the passenger side. Count 1,2,3,4, insert the wire.
Next, pin 9 is located, firewall side, drivers side. Count 9,10,11,12,13,14, insert the wire.
Turn the key on, VSC light should be blinking...you know the rest.
BTW, I am not trying to rude, just trying to provided as much detail as possible.
Ok I tried the jumper wire thing again
But I unhooked the battery first to clear the check engine light first
I put the negative cable back on
And turned the car back on
The check engine light was off and the vsc light was blinking very fast
Turned the key off and pulled the jumper wire started the car and no lights came on
I let the car idle while I reset my nab and radio stations put the car in drive and took a ride
No lights came on until I hit the interstate at 70 mph the check engine light came back on followed by the vsc lights!
What do I check now?
When you get the codes, post them here...
I think your check engine light is causing your VSC light. Sounds like that O2 sensor was no good.
tom63
01-08-09 06:08 PM
