Thanks I will check mine soon. With 118K miles am sure it may look worn out. I will alos be a little sensitive on the ride and see if I can feel anything lag or vibration.
Make sure you check those motor mounts too...I paid $69.71 each, from the dealer.
IMHO it could have easier if I had the correct sockets. I could not get a socket with a universal up in there correctly and almost stripped a head off a bolt. That is when I stopped and took it to a shop I trust. I do believe we had another thread going on this subject...let me look for it.
I do know you need some good six point impact universal sockets.
These are the type of sockets you want. The other knuckle joint type will not fit. I may get corrected but that was my experience.
BTW Mandy, I am using an iPad and I always have to go to advanced to post a picture. If I try to access the insert picture from the basic message entry area, my browser closes. I do not know if it my iPad or the website server. Will you report it? Tks
Bgw70, it is the server. I use photobucket to upload pics and just copy the links when I post. I know it takes an extra step but it is worth it. And uploading is a breeze.
Thanks, what sizes will be needed for the universal sockets, do you remember? I need to go to HF to check these out.
And it is Father's day, I hope to get some FAT HF gift card!
BTW happy Father's day to the dads!
You are so in luck Mandy, I replaced the bolt I messed up but purchased two at the time, which means I have a spare and was just able to confirm it is a 14mm.
