Pros and Cons of Magnaflow High Flow Catalytic Converters
Hi All;
For a while now I have been considering removing my OEM cats for Magnaflow High Flow Catalytic converters. I also noticed that MrMark is running these. Here are the pros and cons of this mod, please feel free to chime in:
Pros:
Increase airflow for more power
Inexpensive
Eliminates greatest restriction in exhaust system
Cons:
Possible trigger P0430 and P0420 code
Loss of backpressure could reduce power (?)
Anyone have anything else to add?
Pros:
Inexpensive
Cons:
Are you planning to track your SC? You won't really 'feel' most of the performance mods unless you're over 60 mph on the curves heading to 110+ on the next straight ... You might want to try autocross though - you will really feel suspension mods around tight turns on slomons. Lower speeds mean more safety and less wear an the care compared to a road course.
Interested in this being the gs has the same as the sc's cats. Anyone have this w/o the CEL? Anyone running it with O2 defouler/simulator? I live in Cali, laws are so uptight with smog emissions I figured to ask.
