Silver Bullet Weight
I just had the Silver Bullet weighed with racing scales.
The total with 5/8 tank of gas w/o passengers was 3758 lbs (3802.55 adjusted for full tank)
[6 lbs per gallon gasoline, 19.8 gal per tank, 5/8 tank = 12.425 gal so missing fuel weighs about 44.55 lbs]
The weight includes the Seibon dry carbon fiber trunk but rest of body OEM. Other mods affecting weight are Mach V 18" 9.5" w wheels, 265/35/18 Dunlap Direzza II Star spec tires. PPE headers, custom SS exhaust, Supra TT diff w/LSD, Carbing fr lower chassis brace, Megan LP coilovers. Added about 10 lbs sound block to rear and Polk subwoofer (much heavier than OEM subwoofer). Some of these mods saved weight while others added weight.
OEM curb weight is reported by Lexus to be 3,840 with full fuel tank.
OEM weight/power of my OEM SC measured on a dyno (wHp) was 3840/233.33 = 16.46 lbs / wHp
Modded July 2015 weight/power = 3802.55/268.38 = 14.17 lbs/ wHp
As I get time I will post the weights of items that can be removed or replaced with lighter items looking at lbs not so much fractions of pounds. Please feel free to add to the list.
Component weight
It would be nice to get the weight/power ratio down to 12.5 or less. Possibily with a piggyback ECU engine mods and perhaps even a supercharger can be added. To be able to build a roadmap of actions it's good to know cost/benefit and limits of the different options.
I am not adding costs to this list because for many options there are several choices and folks in different regions may find different opportunities.
Items that can be exchanged
Trunk lid = 42 lbs, Seibon dry CF trunk lid 14 lbs
Hood AL = 30.8 lbs, Seibon dry hood = 15 lbs
Front fenders = ?, Fiberglass front fenders = ?
Rear fender =?, Fiberglass rear fenders = ?
Battery Glass Matt 760 CCA = 45.66 lbs, Lithium 48 AH = 7 lbs
Front seats = 65lbs x 2 = 130 lbs, Racing buckets = ~ 25lbs each
Rear and side windows = ?, Polycarbonate windows = ?
Reasonable Item that can be removed either permanently or just for track days (I'm not including items nice for daily driving such as air conditioning and thensound system).
Rear seat = 5 lbs
Rear seat back= 8 lbs
Polk sub woofer ~ 10 lbs
Antenna motor =
Headlight washers =
Fog lights =
Trunk lining and tool tray =
Rear seat = 5 lbs
Antenna motor =
Headlight washers =
Fog lights =
istundra
05-17-08 03:52 PM
