Spare Tire Installation with Photos
#61
Bgw70
I am talking about the holes you drilled in the rear cover to make it fit over the bracket. The location for the holes you drilled for the 4 cushions and the starter hole for the bracket? What size is the hole saw 1 inch? Why did you cut out the 2 slots at the lower bottom? Did you cut the chunk out on the very bottom, looks maybe 1/2 inch wide and maybe 5 inches long? And please do not rub it in about the shorts being needed in CF. It was 17 this morning when I got up around 07:30. I believe it topped out at 43
The holes for the rubber bumpers are already in the metal of the car. Just measure the distance vertically and horizontally to locate where to drill. Start small and test fit.
the large cutout was trial and error. I test fitted the cover with the bracket in place, marked it and made my Drimmel cuts.
then checked the fit again and trimmed more. This went on three or four times until I was happy with the fit.
the slits at the bottom were made so the tire would fit better. Put your tire in there and you will see why I did it. The cover sticks out.
#64
I had two SC430s, on the first, I purchased the entire kit…when I did the second car, I purchased some of the parts and cut the non-spare parts using the spare tire parts as a template.
hope that makes sense.
Also, Megazip was a great parts source when I did the second car
https://www.clublexus.com/forums/sc4...l#post10431465
#66
cheezz
02-14-19 05:57 PM
skiptomylo
16
06-15-07 09:45 AM
