2002 430 Climate Control LCD losing segments
Old 08-08-15, 10:24 AM
bobster99
bobster99's Avatar
Default 2002 430 Climate Control LCD losing segments
Good afternoon
I assume that this is something that I am going to have to replace to repair but a couple of the number segments on the LCD display are not working.
Is there any fix for this or is the LCD just telling me that it is time for a new one?
Thanks in advance
Old 08-08-15, 10:41 AM
Bgw70
Bgw70's Avatar
I do not have an answer for you but I know there was a thread or two on this subject...
Try a search using, SC430 AC control LCD
Old 08-08-15, 10:47 AM
Harold57
Harold57's Avatar
More than likely you will have to replace the display. If you are electronically handy, you can attempt to disassemble the control unit and touch up the solder on the pins going to the display. Also, check out the cable going from the control board to the display. (The existence of a cable is an assumption on my part. I don't remember how it is assembled. The display could be just soldered down to the board without a cable involved.) If there is a cable, it is possible one of the pins has come loose on it and is no longer making a connection.
Assemblies like these are not generally made to be repaired. Good luck and let us know what you find out.
Old 08-09-15, 11:52 AM
mandyfig
mandyfig's Avatar
Or you can replace the whole radio. Try fleabay for a whole set.
Old 08-09-15, 07:53 PM
JohnnyCake
JohnnyCake's Avatar
The bad news is that they are pretty pricey, even on eBay. The good news is that the swap will take less than 20 minutes.
Old 08-11-15, 09:58 AM
mandyfig
mandyfig's Avatar
Almost went the way of the whole unit swap. Ended up dumping the CD player (the dreaded CD stuck) and installing an AUX input, could not be happier.
Old 08-11-15, 11:46 AM
Dobriykot
Dobriykot's Avatar
Do you have a problem like at photo or not?
Old 08-11-15, 01:54 PM
Bgw70
Bgw70's Avatar
He is missing segments or pixels in the LCD. The picture you are showing has all of them.
Old 08-11-15, 07:01 PM
Harold57
Harold57's Avatar
Mandy, he is referring to the climate control display, not the radio.
Old 08-13-15, 09:50 AM
mandyfig
mandyfig's Avatar
My bad...am always thinking about the radio...
But fleabay would still be a source for a swap on the LCD I would think.
Old 08-13-15, 03:57 PM
Rollaboy
Rollaboy's Avatar
You have to solder in a used lcd display (i did that and it works) or buy a new or used climate control and replace it all. i got a cheap defect climate control unit but the lcd was in 100% working condition.
Old 08-14-15, 07:59 PM
texsexlex
texsexlex's Avatar
...there was another thread here also concerning the lcd elements & someone posted a company that works on them. I don't think a price was posted,but could be more expensive than buying a used one
Old 07-10-22, 06:32 AM
SCbob508
10th Gear
SCbob508's Avatar
Help please 2002 SC 430 climate control stuck. Popo starting working fine when I left battery disconnected over night and next day connecting negative and positive terminals for couple of hours. The more I used control the less it work. The next day if I don’t shut the A/C off stays on but buttons are not working.
Old 07-10-22, 08:31 AM
Bgw70
Bgw70's Avatar
check to make sure the three connectors in the rear of the control are seated properly…if they are, you may need a new control, check eBay.
also, can you make a YouTube video to show us?
SCbob508 (07-10-22)
Old 07-10-22, 10:32 AM
SCbob508
10th Gear
SCbob508's Avatar
Could it be a ground issue?
Quick Reply: 2002 430 Climate Control LCD losing segments
