Possible ABS problem after replacing front end suspension components
After replacing several front end suspension parts I noticed an issue with the brakes.
The car stops fine and in a straight line but right before the car comes to a complete stop the brake pedal drops about 1/2inch and if I am not holding the wheel, I see it move to the right ever so slightly.
It does it every time and I am thinking that a component was either damaged or is not installed correctly.
Thoughts?
Where should I start?
Thanks!
Thoughts?
Thanks!
That's interesting because I have observed mine do something similar occasionally. It's only happened a couple of times but when it does it, the pedal doesn't drop like yours, but the steering wheel will pull, usually to the right, just as I am coming to a stop, right at the end. I don't feel any pulling during the whole braking, but just riiiiiiight at the end it will pull the wheel.
I assumed it was a brake issue and one of my future projects is the brakes so I figured I would find out then. It doesn't feel unsafe to me, just something noticeable.
The only front end work I have had done was replacement of the LCAs and the owner before me did the tie rod ends. I can't remember if I noticed it before the LCAs as they were done right after I bought the car.
LCA? Lower Control Arm?
Thanks for the input Helo!
I am pretty sure the ABS is kicking in and I should add more symptoms.
I have seen the skid icon light up on the dash for a split second and on two occasions the car would barely accelerate after the stop and when I pushed the gas. It was like the ABS had taken control and was trying to control a skid.
You know, I should turn off the VSC and see if that makes a difference. Duh! LoL
I will report back on the results and I also plan to remove the front wheels and have a look around for something obvious.
If you have ideas, please post them up!
Helo, you were correct, the VSC off did nothing.
My son and I pulled the front wheels to do a visual but saw nothing unusual. We decided to pull the speed sensors to take a look. There was some grease on both sensors and we wiped it off. We also disconnected the battery and left it that way while we worked on the front wheel, 15-20 min.
We then put everything back together and took it for a test drive and the brakes are working correctly! All is good and 100%
Thanks for the help Helo!!!
That problem sure had me perplexed but I knew it had something to do with the front end work.
Either way, it is fixed but I do not know if it was the skid control ECU reset or cleaning the grease off the sensors.
erosby (03-20-18)
Tex, I think you are so correct! As part of the alignment they do have the key on and he may have bumped or adjusted the sensor bolt.
Thank you so much for your input. Every idea can help someone directly or give them an idea!
It is nice to have highly intelligent people in this forum, all of you are very helpful and I thank you!
erosby (03-20-18)
ddvette9
Suspension and Brakes
08-03-15 03:02 PM
