Convertible top problems - the package tray
Old 10-25-15, 02:33 AM
Bgw70
Bgw70's Avatar
Originally Posted by hitsofmiss
Harold, did you get it done at Lexus Dealer for $944? Wonder why my dealer quote $2500 for parts & labor?
See post number 5. Harold said they are an independent shop, but know Lexus, which means they are not a Lexus dealer.
Old 10-25-15, 01:48 PM
Harold57
Harold57's Avatar
Bgw is correct. The shop is an independent shop that was started by former certified Lexus mechanics. They are independent from Lexus but can read Lexus proprietary error codes. That is why they are so much cheaper than going to the dealer.
I never got a quote from the dealer for other than a diagnosis.
Old 10-27-15, 12:12 PM
Jake125
Jake125's Avatar
Thanks to all for this information. I am just putting away my 2006 SC for the winter. This is my first year with my Lexus. I enjoyed a great summer with my "new" 430. The car has never seen snow. I need all the help I can get as my vehicle looks like it just came out of the showroom and I want to keep it that way! Thanks Again!
Old 10-29-15, 03:12 PM
hitsofmiss
hitsofmiss's Avatar
Just got a call from Lexus & they said the roof issue is due to Left Hand Package Tray - Part# 64302-24020 for $2200.
They also said since I'm in it, it would be better to replace the switch which will be additional 2*$1700 = $3400......... though, I don't need it. In any case, I think I'm going to pass the offer from the dealer.
The cheapest I found online was for $450 + S/H. However, I accidentally stumbled upon a site & it was going for around $275. Can't find it anymore.
Old 10-29-15, 03:59 PM
Coleroad
Coleroad's Avatar
I saw one on eBay today. It was a scrapyard. I think for $125
http://www.ebay.com/itm/2002-2010-Le...1WBesV&vxp=mtr
Old 10-29-15, 05:26 PM
hitsofmiss
hitsofmiss's Avatar
Thank you Coleroad. While talking to TLS Auto, I realized that they sell the entire assembly or just the motor (both having the same part number) for $450 & $250 respectively. The picture also looks quite different.
Anyway, I ended up ordering the entire assembly for $325 & it comes with the 1 yrs warranty. Keeping my finger cross. Now, I just have to find an independent Lexus mechanic.
Old 10-29-15, 05:40 PM
Coleroad
Coleroad's Avatar
Yes, maybe with all the hinge assembly attached it will save on labor.
Old 11-07-15, 11:23 AM
Harold57
Harold57's Avatar
Linking this package tray thread to an earlier one for future reference.
https://www.clublexus.com/forums/sc4...op-issues.html
Old 11-07-15, 11:28 AM
hitsofmiss
hitsofmiss's Avatar
Arrgh! My Lexus Support Consultant gave me wrong part number over the phone, I came to know after I ordered 64302-24020, which is actually Package Tray Limiter Switch No. 2 (Bracket Sub-Assy, PA).
It's called "Package Tray Trim Link Left Hand Motor Assembly 85730-24030: Motor Assembly, Slide RO". TLS Auto does not have it & the lowest price I've seen online is around $270.
Old 11-07-15, 01:32 PM
Harold57
Harold57's Avatar
Yes, 85730-24030 is the correct number. (You can see it on the box in the picture I posted earlier in this thread.)
Old 11-08-15, 03:26 PM
Harold57
Harold57's Avatar
Well, I was going to take the old motor apart to see if I could identify the failure and fix it but it is pretty robustly made. It appears that all you have to do is to remove the bracket on the bottom and then straighten out the three metal tabs that are bent over the plastic portion of the housing. After that the internals should be reachable.
But the metal tabs are pretty thick metal and really difficult to straighten out. I decided that I valued my hands more than satisfying my curiosity and stopped before I wound up running a screwdriver through my fingers or hands.
However, for the benefit of the discussion, I suspect that the motor is fine but there is likely a relay of sorts inside the plastic portion of the enclosure. Once one could get to the relay, the relay could either be replaced or have the contacts cleaned (if the relay was built in a manner that would allow service).
Old 11-10-15, 08:36 PM
hitsofmiss
hitsofmiss's Avatar
Hi Harold,
How difficult is it to replace 85730-24030? Will you be able to send some step-by-step instructions with pictures?
Old 11-11-15, 05:48 AM
Bgw70
Bgw70's Avatar
Hi Harold,
This will give you an idea, just click these words and read the whole thread...he thought it was the cable but it turned out being the motor. He posted pictures.
Old 11-11-15, 01:24 PM
Harold57
Harold57's Avatar
hitsofmiss, I hired an independent Lexus shop to do the work. It sounded like a lot of effort to get to the motor when they described it to me. Sorry but I have no pictures (I asked for some but they didn't provide any) nor was I there when they took it apart.
Old 11-11-15, 01:57 PM
Harold57
Harold57's Avatar
Great link BGW. That must have been one of the years I was traveling since I don't remember the thread. Thanks.
Quick Reply: Convertible top problems - the package tray
