Initial Engine Idle Not Going Down As Usual
My '06 SC has about 72k miles and I've notice of late after starting it, it initially idles at about 1,200 RPM and tends to stay there until after driving and warmed up and then goes down. It used to start up at 1,200 RPM and after a very brief period of time would settle at 1,000 or 800 RPM, I can't recall exactly. My question is, is this normal related to the life of the engine, or do I have a sensor or other type of issue that can be addressed. My gut thought is that this is sensor issue, but am not sure which one to test or replace first.
Thanks in advance for any answers or thoughts.
It is not normal, I would first clean out the throttle body and run a code checker. If cleaning the TB and no codes are detected, I would then begins the process of looking a malfunctioning sensor...
I would also check for a vacuum leak...check vacuum hoses and idle air control...again could be carbon build up.
It will most likely be an easy fix.
When the engine is cold. The ecm is in open loop. It is not reading from all the sensors. Once the car is warmed up. It is in closed loop. It is now reading from all the sensors. Since the problem is solved by the car being warm. The computer reading from the sensors is able to compensate for the real issue. I would start with cleaning the throttlebody.like Bgw said a vacuum leak is a good possibility too.
No luck, the car starts up at around 1,200 RPM and does not want to go down with the press of the gas pedal after 30 seconds of idling. Does anyone have any thoughts on which sensor could be the culprit? Also, with no check engine lights on, would a good OBD II code reader find the sensor? Thanks in advance for all replies.
Check for a Vacuum leak and idle air control valve.
Google the how to check these items and watch some YouTube videos...
Thanks,. the idle air control valve makes a lot sense at what to look at or replace first. I did check for a vacuum leak yesterday and could not find one, but I may have a mechanic do that.
Smoke test is the only viable way to find a small vacuum leak. You could spend hours trying to find it otherwise. If you don't mind, how did you go about cleaning the throttle body?
I took off the air hose attached to the throttle body and inspected it first and it looked very clean, no visible dark deposits of any kind. I then sprayed cleaner, specifically for cleaning the throttle body, with both the choke plate opened and closed.
Because I could not solve the problem, I took the car to a Lexus dealership and they spent one hour of time and told me there is nothing wrong with the car. I could not disagree more, I know how these cars idle when started up. Something is wrong, but they simply cannot detect it, frustrating. What I don't like about the conclusion of this dealership is that I know how the car is suppose to run and verified it with another owner over the phone, but because the computer reading say it's okay, they believe it vs having very experienced mechanics who could recognize this malfunction.
Thanks for video. I owned another car that had a rough idle and did exactly what that video showed and it did smooth out the idle. Unfortunately I do not think it is the idle air control valve, the idle is very smooth, not rough at all, just stuck at high RPM's. Typically when the car is started on a cold day the idle used to drop down fairly quickly or did so by tapping on the gas pedal, now it won't. I think it's sensor going bad.
sherwoodjb
01-26-11 07:43 PM
lexdud
Performance & Maintenance
13
12-29-09 09:25 AM
