What did you do to/for your sc430 today?
#1651
It will work either way, but it is always best to polish the headlights before coating.
#1652
daddio, yes, as its name, this spray is not a headlights polisher. It will not remove the haze but coat a thin layer of protectant to protect the headlights from UV damage.
#1653
[QUOTE=doobs;11530712]Just out of curiosity, why these over the MeisterR ZetaCRD unit?
actually these didn't even come up in conversation. I started to look around & a few brands that I looked into came up on the Redline360 site. I talked to one of the guys there & another company about what I was looking for (options,price range,etc...) & these kept being their top choice.
#1655
club lexus comes through again!
after three years, i finally got around to it this morning. it took about an hour.
i don’t listen to the radio and i prefer the cleaner look with the antenna down anyway.
partial removal of trunk liner was required to expose the antenna motor and then i just unplugged the power cable. no damage and if necesssry i can just plug it back in for original functionality.
got all the info i needed from the forum, just had to search for it.
#1656
Well not today, but a couple days ago... I replaced a damaged package shelf and while I was at it I lubricated all the workings for my power top.
Replacing package shelf ? - ClubLexus - Lexus Forum Discussion
#1657
Timing belt/water pump/tensioners/drive belt today. My guy said the water pump was leaking so catastrophe avoided.
Adjusted the spacer below the package shelf, back seat rattle now gone.
Detailed the front seats with 2 step Lexol, they look great.
Motor mounts still to do and an alignment & wheel balance to hopefully get rid of the 55 shimmy.
#1658
Make sure shimmy not coming from an unbalanced tire, good luck.
#1659
Toyota/Lexus water pumps are designed to weep a small amount of fluid to keep the seal lubricated where it mates with the shaft. Because of this, the engineers design their water pumps with a path for the seepage to flow down and out of the way of any parts that could otherwise be contaminated. Oftentimes, people (even mechanics) replacing water pumps will report the part was leaking, while it may only have been weeping or seeping as designed.
I'm not contradicting your mechanic because I didn't see the "leak" myself. I'm only suggesting he might not be aware of the intent of the designers, so, may have wrongly reported the leak.
#1660
#1661
mandyfig (11-09-23)
