What did you do to/for your sc430 today?
#496
Great thanks for confirming the gas door release!
I have seen members here who made small cutout (around 1.5 in) in carpet area to adjust the coilover, which I am planning to do as well. But after uninstalling the whole trunk, I am really leaning making a larger cutout, like 4-5 inch, on mine so I can access the bolts for the coilover, if I ever need to make any changes.
I cut a large hole and used a drain pipe stop end to fill the hole.
![](https://cimg1.ibsrv.net/gimg/www.clublexus.com-vbulletin/768x1024/img_20120531_00509_5f084d325d7667c8f74ca9929cf61858c34feaba.jpg)
![](https://cimg3.ibsrv.net/gimg/www.clublexus.com-vbulletin/768x1024/img_20120531_00506_29e9f182c9efd38cdadc1590d30407ae3e4be642.jpg)
![](https://cimg5.ibsrv.net/gimg/www.clublexus.com-vbulletin/768x1024/img_20120531_00511_5df607331d72d4d5a4a475400f3c053be4e6f74c.jpg)
Cheers Steve
JDaveSC430 (04-10-17)
#498
Steve - thank you so much. I went to Lowes and Home Depot earlier in the week. I could not find anything that would work that are larger than 2 inch. I am getting a weird look too from asking them for anything round that I can use to cover a hole in my car haha...
#499
So why not use the piece that you cut out? On one side put a tab on the bottom with a short screw. On the other side put a tab on top with a short screw, and put a piece of the rough side Velcro so that top tab sticks to the trunk carpet. Kinda like I mocked up in this picture.
#500
Any marine supply company has plastic access hatches that have a border that you could screw down to the trunk material and then the center of the hatch unscrews or you pop it up. There called inspection ports. I used them on my boat deck so I could get access to the water intake .
Jabberwock (03-22-17)
#501
#502
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
TitanG545 (05-20-20)
#507
While installing the front coilover, I find out the boot on each side are ripped
I borrowed this picture from Bgw70's thread, but this is the boot that are ripped on mine. I think it is called outer tie rod, right? Can I just replace the boot, or might as well replace the outer tie rod as well? OEM or aftermarket? I guess the SC is going to be sidelined a bit longer... and more research time for me how to do this...
#508
BCT (04-09-17)
#509
Thanks, Coleroad! Got to spend quite a bit of "quality time" with the SC430 this week.
The weather continued to behave so I did the front struts on Friday with a quick trip to the dealer for a alignment on Saturday. Went with the KYB Excel-GR2's on the front. While I was in there I replaced the upper control arm / ball joint with Moog units and got rid of the metal clanking sound when going over rough roads by replacing the strut mounts. Totally different ( and much improved ) over the very worn original parts.
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
#510
