What did you do to/for your sc430 today?
#706
Nice touch Shawn.
#707
Thanks for replies. Today I'm cleaning intake with CRC manifold solvent.
new PCV valve, Mobil 1 synthetic oil change, & the transmission fluid replacement via trans lines. Next week I'll be flushing/cleaning my fuel injectors via OTC non dismantle system.
#708
is that what you are using?
#709
Yes. That's it. Remove fuel pump fuse, disconnect fuel line from tank line under hood near oil filll on my 02 &
You hook it up to air compressor to running PSI, mix gas & solvent cocktail & run till she quits. 1 or 2 applications to fully clean. Several write-ups on here. Thanks
#710
......over the last week,
1....changed the oil
2....drained & filled transmission
3....replaced the brake fluid
4....replaced the power steering fluid
5....replaced the injen intake air filter
6....replaced the cabin filter
7....replaced the wiper blades
8....installed new spark plugs
9....installed new front brake pads
2 things left to do...
1....replace rear brake pads
2....drain & refill coolant system
texsexlex (12-16-18)
#715
Thanks. I'll be watching it carefully. Was working on the valve cover bolts (tightening them) this afternoon, and might have pushed up against some hoses. Light came on for the first time. Oil and all is good. So not sure why it suddenly came on. Someone on the site said to disconnect the battery cables, and reset. Did so, and sure enought the light went out and never returned. If it comes on again, I'll take it in to the shop. ps: getting to the valve cover bolts is a real pain. Thanks.
#718
texsexlex (01-02-19)
#720
Improved conditions
I decided that my 2003 SC430 needed a better living environment.. so.. rainy/cool mornings here
kept me off the golf course and in the garage. I have a few more things to do before my
"project" is completed..but so far I think my car is a bit happier!
