What did you do to/for your sc430 today?
#76
It wasn't to bad. I swapped it without removing the whole throttlebody. It to a little fiddling to get the bottom screw out and back in. I used a Philips socket on a short ratchet to get it. Otherwise it was straight forward. Adjusting it is simple if you can read absolute throttle percentage. I did find I needed to set it at abou 13.7 % . It was running just over 1400 rpm at 14% on initial start up. Then down to 950 rpm. It now is 1200 rpm and settles in around 750 rpm.
#77
I have a 2006 model. I installed the NavTool backup camera and Vais Tech SL3B bluetooth for the radio. I love the special feature of the Vais that it enters the "I Agree" on the Nav screen at start-up.
#78
Hey Poqman, do you possibly mean the SL3B from VaisTech? Are you using an android or apple phone? I only ask b'c i have a few questions now that you have it installed. Once you're using your phone to play music via bluetooth, if you try to change the track via the steering wheel controls, will it actually change the track on the phone? Secondly, does the radio display either the track name or any other information? Maybe some photos would be nice too! Thanks!
#79
I have not gotten any text functions to work. The display always shows disc 1, track 1 and 0'00 seconds. The last step of the CD emulation instructions says CHECK SOUNDLINQ3 FOR FUNCTIONALLY, ESPECIALLY TEXT CAPABILITIES. All the functionalities seem to work, but not the text. I tried going through the setup 3 times. Always the same outcome. Tomorrow, I'll give it one more try. I installed a similar unit on a RX330 without Nav and the only text was the countdown seconds as the song played. No Playlist or song names displayed on the RX330 either.
#80
ShawnOk, I looked at the VAIS Tech application guide and the 2005-2009 SC430 says NO in the TEXT column and that's what I'm getting. The 2004-2006 RX330 says YES in the TEXT column, but the only text that changes is the track and countdown. The Text feature doesn't seem to get you much unless your car displays the audio through the NAV screen.
#81
Good info on the Vaistech. I might be opting for a different brand for the mean time. Need to do some saving. Hehe
Not alot has been done on my SC as of late. I drove it to work for the pass few days and enjoying the top down on the way home. Ran the SC on a straight highway at 100mph a few times and enjoyed the ride. Felt a few things need to be replaced (springs, etc.) but the ride is still good. Ever so suddenly after my parking sensors were working to my surprise (I never knew my version had it). But it was a bit inconsistent. Yesterday during lunch it didnt work, but later that after it did. Any suggestions to this?
#83
Replaced all interior lights (including the vanity), with LEDs. Love the cool white.
The map lights are not bright enough (I bough LEDs only have 13 lm), reordered brighter LEDs with 95lm.
Next step, I am going to replace DRLs and Fog lights with LEDs.
#86
Thanks! I found one of the evap lines had come loose before I got started. After reading, others mention that this specific hose commonly gets disconnected if there's too much play in your motor/transmission mounts. Interesting unintentional built in motormount wear indicator.
#88
I went and had inspection done, and it failed. I got a new battery a month ago and had driven only ten miles since. That is why it failed. So I took it out for a long drive. It passed today. What irritates me about it is that the car fax will show a failed emissions. It will be viewed as something was wrong with the car when in reality there was nothing wrong with it. I did enjoy the ride though. I got lost and had to use the gps to get home lol
#89
#90
Got around to doing my steering wheel swap today. Went pretty well except that I didn't have an extnesion for my socket wrench which turned a 15 minute job into a 2 hours ordeal. Also, I installed a hard wired Qi Car Cradle to charge my phone wirelessly. Had a modify the original Qi cradle a little to avoid the tilt steering when I remove the key from the ignition. Turned out pretty nice in the end, and no more worries about my phone dying.
