What did you do to/for your sc430 today?
#916
my custom grille
I just completed and installed my custom grille that I etched designs into. Took a while with the detail.
I know this is quite unusual. I hope you guys like it. Had a few chips I had to fill.
joemg (10-14-19)
#917
#919
This is a pretty subtle design so at ten feet you won't see very much detail. In fact this was difficult to photograph. The detail was either lost or showed all my mistakes. This is the first time I am etching the grille and found out that the black plastic underneath shows through if I sandblast it excessively.
#920
It all starts off using a Cricut cutter. This amazing machine cuts your chosen design. Then I apply the cut vinyl design to the surface and sandblast the design into the surface. It's a long and tedious process. But I'm retired and have a lot of time and imagination (scary). Check out my post on; What did you do to ……(my custom grille)
okievision (10-16-19)
The following 2 users liked this post by Drbrdb:
forbirdie3 (10-21-19),
Lavrishevo (10-19-19)
#927
Before: Tein S-Tech on OEM shocks: 21x9 +34 (255/30/21) and 21x10.5 +20 (295/25/21) running Toyo T1R.
After: BC Coilovers: 19x9 +15 (245/35/19) and 19x10 +15 (275/35/19) running Continental ExtremeContact DWS06.
Current fitment pics:
digitatc (10-23-19)
#928
Replaced 2 front tires today. Replaced the rears last weekend.
Since I have the wheels off, I tried on the Supra TT caliper & rotor (just received) to compare with the original set and it's obviously look much bigger.
Front tire
Rear tire
How the car sits with the new tires.
Comparing the original caliper & the new Supra TT caliper
and the larger rotor
Front tire
Rear tire
joemg (10-27-19)
#930
Preventative maintenance
Had the valve cover gaskets, the engine air filter and the sparkplugs renewed at 120k miles. I did the air filter, had the rest of the work done at the Lexus dealer. The old plugs were is fairly good shape.
The Lexus dealer gave me a better price than the Toyota dealer. If you are NE, PM me for the name of the dealer.
When I was picking the car up I saw a SC430 that needed a $5k ECU changed
