What did you do to/for your sc430 today?
Old 10-09-20, 07:12 AM
  #1216
sc4tlc
sc4tlc's Avatar
Originally Posted by BrazenC5
What components did you use to add Apple car play and Android connect interface?
Looks great.
I agree. Interested in details.
Side note: the vent looks like it's pushed in a little.
AnniesRide (01-21-21)
Old 10-11-20, 10:24 PM
  #1217
Seattle SCone
Seattle SCone's Avatar
Replaced old steering rack bushings with Figs Engineering polyurethane bushings. Before the swap, the old bushings allowed the rack to move back and forth about 8 mm when moving steering wheel left/right with car parked. Now, I can't see any rack movement and steering is more immediately responsive. No change in noise nor noticeable steering wheel road vibration. Should have done this ages ago.
Old 10-18-20, 06:14 PM
  #1218
SeaStories
SeaStories's Avatar
Had new front brake rotors and pads from Power Stop installed. I got the K1077 kit:
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
They were a little grabby for the first few miles, but seem to work fine now. I haven't noticed a difference in performance, but I've never had a serious braking situation with my SC before or after the new brakes.
SeaStories
Old 10-23-20, 10:33 AM
  #1219
Andreiu
Andreiu's Avatar
Default Diy Unalignment!
Today, I gave my car an Unalignment.
My car always pulled to the left, so I got toe plates and a digital inclinometer. I found that total toe was OK but the Dr side tire was straight and the PA tire toe in. Camber was a little off on DR side.
I was stupid and didn't mark my starting point on the camber bolt and cannot get it right haha.
I'm gonna make a stand with 2x4s so I can adjust it with weight on wheels this weekend and get it right.
Old 10-23-20, 10:36 AM
  #1220
digitatc
digitatc's Avatar
That's pretty cool. Something I need to learn.
Old 10-23-20, 10:49 AM
  #1221
Andreiu
Andreiu's Avatar
Yeah, it was pretty obvious what was wrong.
I used a large washer stuck under the horn and a level to keep the steering wheel straight as I rolled into the garage.
I tied a piece of string to my rear rim and found the DR side wheel was almost perfectly parallel while the PA side was turned in.
You're supposed to adjust caster, then camber, then toe. We don't have caster adjustment so I went straight to camber and got it all out of whack.
Old 10-23-20, 10:55 AM
  #1222
Andreiu
Andreiu's Avatar
SeaStories
I have power stop pads and slotted rotors as well. I followed their instructions for braking them in, but it wasn't until after an actual track day that they really bedded in. Now as soon as they warm up, the brakes are seriously good. What surprised me was how fast the rotors ate up the pads. I replaced them in February and barely go anywhere due to the pandemic, but my pads are already down 30%. Not a big deal, but make sure you check them more often!
Old 10-23-20, 11:17 AM
  #1223
SeaStories
SeaStories's Avatar
Thanks for the tip. I'll keep an eye on them.
Old 11-08-20, 11:45 PM
  #1224
Seattle SCone
Thanks to threads in this forum, my 222K+ 2002 got some love
Changed power steering fluid - was already working well, but seems lighter to touch after change.
Changed transmission fluid (5 speed) - slight delays between gears are now gone with fresh Toyota T-IV. Old fluid was brown.
Changed spark plugs from original Denso to NGK's - Amazing the old ones lasted this long. Gaps on old plugs were about 0.048. After transmission fluid and new plugs, she accelerates more aggressively.
Only bad thing was discovering oil in 2/3 of my spark plug wells. Seems to be slow leaks as there is NOTHING venting or weeping to outside of valve covers. Adding a valve cover gasket job to next week's front suspension rebuild.
Old 11-09-20, 12:02 AM
  #1225
Natroth
Natroth's Avatar
Default refurbished the rear speakers and got control of my quarter windows
I had to strip the back of the car to install my rear quarter window control module and discovered two very sad rear speakers. With a kit and a bit of extra effort, my rear windows go up and down when I say so AND I can hear my rear speakers again !!! OK, what's next?
Andreiu (11-29-20)
Old 11-14-20, 05:58 PM
  #1226
Ozrkcowboy
Ozrkcowboy's Avatar
New TSW Sebring wheels
mandyfig (12-08-20)
Old 11-15-20, 05:19 PM
  #1227
Dx3
Dx3's Avatar
Replaced the antenna that was broken and sounded awful when I turned the radio on.
Old 11-16-20, 07:35 AM
  #1228
mandyfig
mandyfig's Avatar
Looking good! What did you do to your RR quarter panel to be able to bring them up on demand?
Old 11-16-20, 11:28 AM
  #1229
bmanone
bmanone's Avatar
Cleaned the throttle body intake and the mass flow air sensor Wednesday (for a noticeable improvement in throttle response and drive-ability). Installed Daizen Polyurethane Steering Rack Bushings Thursday, discovered the LH tie rod is warn out (ordered Mevotech replacements for both sides). Washed the car Friday and waxed it Sunday.
Old 11-16-20, 02:19 PM
  #1230
JMal
JMal's Avatar
Hi Dennis,
Did you or your son do anything to adjust the speedo to account for the taller tyres?
Quick Reply: What did you do to/for your sc430 today?
