What did you do to/for your sc430 today?
Old 07-23-21, 06:55 AM
  #1366
Autoplak
Autoplak's Avatar
Installed a Magnaflow 16917 cat back exhaust coupled with a previously installed WeaponR CAI. Have yet to turn on the radio. ;~)
Old 07-24-21, 01:21 PM
  #1367
Bgw70
Bgw70's Avatar
Originally Posted by Buster06
@430in303 what do you call that piece, and how do you remove it?
I am not sure what you are trying to show…the pic is way tooooo small.
Old 07-24-21, 01:58 PM
  #1368
SC430fun
SC430fun's Avatar
when I installed the weapon or intake and I revved my engine I was disappointed. But then I decided to take it for a drive and when the car is in gear and the engine is under load is when it sounds completely different and it’s quite glorious!
I had to take off my weapon R intake.. but my car is ridiculously loud with flow masters, X pipe in place of 3rd cat, 2.5” true dual exhaust.
I’m going to put on the intake this weekend or maybe next weekend with the cold air intake tube attached and possibly a cheap metal shield from eBay that is adjusted to fit to keep out much of the hot air.
Old 07-27-21, 06:49 AM
  #1369
tabasco
tabasco's Avatar
Default Zainoed
The following 2 users liked this post by tabasco:
JTho (08-03-21), SC300Es (07-27-21)
Old 07-27-21, 05:29 PM
  #1370
jimisbell
jimisbell's Avatar
I thought it was on this forum that I found the information, but have been searching all day to no avail.
Where can I find the source of the front bumper cover kit that comes from Poland????
Old 07-28-21, 11:23 AM
  #1371
WIL44
WIL44's Avatar
Hi Jim
The last post I can find from Neil E is #18 on this thread. https://www.clublexus.com/forums/sc4...our-sc430.html
DM Neil and he will give you the info you need.
Neil E (07-28-21)
Old 07-28-21, 01:24 PM
  #1372
Neil E
Neil E's Avatar
Originally Posted by WIL44
Hi Jim
P.M. sent - try these guys, they may be able to help but be prepared for some work to make it fit neatly. It's designed to fit as a complete kit so may need some adjustment.
https://www.ebay.co.uk/itm/402065526...EAAOSwoCdd4PW1
WIL44 (07-29-21)
Old 07-28-21, 02:42 PM
  #1373
jimisbell
jimisbell's Avatar
I could not log into the UK Ebay with my US Ebay account. Do you know if they have a URL that I can log onto. I really like that front end. If I cant get it I will just take mine off and use fiberglass to modify it before I paint it. But I know I will like theirs better.
Old 07-28-21, 02:51 PM
  #1374
jimisbell
jimisbell's Avatar
Well, I got into the UK Ebay...so I am on the way.
WIL44 (07-29-21)
Old 07-28-21, 05:04 PM
  #1375
jimisbell
jimisbell's Avatar
What I did surprised some people. I took the top down when I left the restaurant after lunch. But the real crowd was when I got to the first red lite after determining that 92 degrees was too hot for top down and while waiting for the light, I put it back up.
Neil E (07-29-21)
Old 08-03-21, 07:17 PM
  #1376
siddu
siddu's Avatar
Originally Posted by DJWLDW
I could not get that lock clip for the electrical connection to budge. I am assuming that you just pinch it in and slide it off. But I get no movement what so ever even shaking it up and down while trying to slide it off.
Dennis
i just did it! That happened to me in the beginning until I started getting mad. Then I pressed harder than I should have and it came out without me even wiggling it. Maybe you aren’t pressing it down hard enough?
Old 08-04-21, 07:05 AM
  #1377
DJWLDW
DJWLDW's Avatar
siddu
Thanks for the update but I am sure I am more afraid of breaking it than the results I expect to get if I clean the filter.
Dennis
Old 08-04-21, 07:38 AM
  #1378
mandyfig
Forum Moderator
mandyfig's Avatar
Some spacers will be good for your rims. I have the same rims.
Old 08-21-21, 08:10 AM
  #1379
doobs
doobs's Avatar
Gotta ask the question....
Do you replace the wheel studs when adding spacers between the wheel and hub? I've never thought there was an excess of thread for the studs without spacers.
thanks
Old 08-21-21, 02:10 PM
  #1380
mak99
mak99's Avatar
thanks
I used these spacers on mine - 25mm front, 35mm rear:
https://www.ichibausa.com/ProductDet...=WS%2D5511467A
Quick Reply: What did you do to/for your sc430 today?
