Bought a 2002 SC430 today. Can't drop the top.
Old 11-23-15, 09:35 AM
Bgw70
Bgw70's Avatar
Originally Posted by Retroplay
The Techstream cable I mentioned would be the better investment. Not only can it read the trouble codes, but it also allows you to customize some features of your Lexus.
And it allows you to run diagnostics.
Old 11-23-15, 09:37 AM
ShawnOk
ShawnOk's Avatar
Do both windows roll down? If for some reason they are damaged and won't roll down, that would inhibit the top drop feature. Secondly, the tonnaeu cover sensor can be "jumped," to make sure that it is not faulty. In the trunk only one side (driver) has this sensor. You can remove it and just disconnect the harness and connect both wires to give a constant loop to the control the sensor as if the cover were in place.That would tell you that this switch is bad. Theoretically, you can do the same thing with the valet switch in the glove box to test if that switch is defective.
Old 11-23-15, 11:20 AM
fraggin
fraggin's Avatar
Thanks. Ordered the cable. It should be here this week.
Old 11-23-15, 11:23 AM
fraggin
fraggin's Avatar
Thanks for the tips. Both windows do roll down. The valet switch appears to override the trunk switch, so is it safe to assume thats not the issue?
PrinLexa (09-16-19)
Old 11-23-15, 12:43 PM
Bgw70
Bgw70's Avatar
These pages may help...the blinking light means the conditions have not been met to operate the roof.
If it were me, the first place I would check is the trunk cover micro switch.
PrinLexa (09-16-19)
Old 11-23-15, 12:57 PM
fraggin
fraggin's Avatar
Thank You. You guys have all been very helpful. I will have some time this week to really dig into this issue, I will update once I have more information.
Old 11-23-15, 01:15 PM
mandyfig
mandyfig's Avatar
The rims are for 2006 and up, nice! What kind of rubbers are they on?
Old 11-23-15, 01:44 PM
Bgw70
Bgw70's Avatar
You mentioned in your first post that it only blinks four times, I tried mine today with trunk cover rolled up and I stopped counting the blinks at 30...
I will look through the manual and hope the four blinks actually mean something.
Old 11-23-15, 01:50 PM
Bgw70
Bgw70's Avatar
Also, you could try to manually open the top.
Old 11-23-15, 01:52 PM
Bgw70
Bgw70's Avatar
BTW, there are only a few things that could go wrong ;-)
PrinLexa (09-16-19)
Old 11-23-15, 01:57 PM
Bgw70
Bgw70's Avatar
In a previous post there is a picture of the PROBLEM SYMTOMS TABLE. The first item tells you to go to page 05-1416. Here is the page.
Old 11-23-15, 02:01 PM
Bgw70
Bgw70's Avatar
I believe the unlock is first thing that happens in the sequence.
Old 11-23-15, 02:13 PM
Bgw70
Bgw70's Avatar
BTW, here is a stupid question...has the battery ever been disconnected Or replaced after this problem showed up?
If not, disconnect it for 5-10 minutes...
Old 11-24-15, 03:04 PM
fraggin
fraggin's Avatar
I couldn't say for sure, but will definitely try to disconnect the battery.
Old 11-24-15, 11:31 PM
Cube
Cube's Avatar
Guys, is this the same software for TechStream? I read the PC requirement that it could run on Vista and Windows 7.
stich (06-26-22)
Quick Reply: Bought a 2002 SC430 today. Can't drop the top.
