Hot air on feet with hardtop down - Solution Teaser
It should move both mirrors down,,and only if the mirror adjustment control is placed in the right or left position. If that control is in the center or neutral position, the mirrors will not move when the car is placed in reverse
Yes, the gain (and treble) increases when the top is down (probably for wind noise as guessed above) BUT also the phase of the speakers is reversed when compared to top up. I've tested this many times and it's something that has been discussed over the years on this forum. Secondly, both mirrors should angle downward to help with reverse parking between lines when the mirror adjustment panel is placed in either R or L (not middle) and gear selector is in REVERSE. Upon shifting to park or drive, the mirrors will angle back to normal driving position. I don't believe it has anything to do with the slope that the car is sitting on. As for the headlights, after lots of trial and error with a failing right height sensor, I found that the car will only adjust the headlights at startup (ie. the headlight "bounce"--- which can be deactivated by pulling the leveling fuse on the passenger kickpanel). If they are bouncing up and down while in motion (as mine were), the driver should investigate either a failing front (driver) or rear (driver) ride height sensor.
They are specifically called "Ride Height Sensors"?
And only one on the drivers side rear.
That video is quite accurate. There are only two ride height sensors on the SC430. One behind the front right drivers side tire. It is attached with two 10mm bolts, a wire harness (very hard to detach), and an adjustable arm link to the "suspension arm." In the back, there is only one behind the rear drivers side wheel. It is also attached by two 10mm bolts, a wire harness, and another adjustable arm link to the rear "suspension arm." I took two sets off a vehicle this past weekend, pretty easy once you remove the wheels. One car didn't have the wheel lock key and it was really tough. Had to jack the car up and literally place myself under the car and then keep turning the steering wheel to opposite side to let me get into the space behind the tire. Plus dangerous if the jack slipped. I was scared, for sure.
An additional note, if you purchase these NEW from Lexus or online, they will need to be programmed by Lexus and that gets CRAZY expensive! If you can find a used one, it has already been programmed and thus is just plug and play.
Also, I didn't open mine up and clean it as above. I didn't know that was even possible. I just purchased a used one from a part out and problem is gone. By the way, while mine we're bouncing up and down while driving (indicated by getting flashed highbeams by oncoming drivers), my headlight level dash error light was never illuminated. In the past it had come on a few times but could never get it illuminated when I took it in for diagnostic. I took it to Lexus twice and they ran "free" diagnostics and never came up with anything, or so they say. I finally got fed up and said they need to check the front ride height sensor, and they stubbornly said they did check them and if I wanted them to check it again, they would charge me (i think $139). Paid them. results finally came to say bad front ride height sensor. After a lot of wasted time and money, got a new sensor for $100. Plug and play replacement and now no problems.
That was a good video!
It would have been nice if he continued on with the cleaning process...
When I replaced the front end bushings and rear sway bar bushings, the two height sensors were encountered. One front and one rear.
I don't get a headlight error either, but I have noticed my lights bouncing while driving. I assumed that they adjusted constantly for incline angle.
I'll be cracking mine open when we get a break in the weather to give mine a cleaning. When I do, I'll post up about it with more pictures.
