Drivers seat heat does not work HELP!
Got my 2002 SC430 in September of 2015 all is good but the drivers seat heat does not work. Passenger side works fine. Both lights come on when the switchs are turned on but no heat on the drivers side. Looked in the manual for separate fuses but no luck. Anyone had a similar problem and got answers or fuse locations? Thanks for any advice.
Same situation, although mine works intermittently (mostly not).
There are some threads on this and the upshot is that this is usually caused by a break in the heating grid that is glued into the seat. The repair is next to impossible and a real PITA. If you go to the dealer, they say buy a new seat, which is several thousand dollars and then it won't match the passenger's seat color/wear.
Of course, check the switch first, but you say you are getting a light there, so doubtful that's the problem.
I agree with JohnnyCake.
You can also look for a used seat but then it is kind of a crap shoot as to whether the leather color will match (most likely not) and if the element in it is good also (regardless of what the ad states).
Cost of seat cover installed would have been almost $3 thousand. Yep, that paid for warranty right there.
Had the car for 5 years before the seat element broke. Dealer says it is just usually age and brittleness of the wiring, and, always the driver's seat for its constant usage.
No other fix except to replace the leather; so sorry!
I have 2005 sc430 no issue with this car. My other daily driver a 2004 gx470 with extended warranty same issue the drivers side bottom and back rest did not work they removed the seat and took off leather seat bottom and back and replaced grid . Under warranty would of been expensive
They hooked both up to the driver's side electrical several times with the same results and they were correct. When they replaced the leather, they showed me the area which had an apparent crack or wear and had become overheated and triggered a safety shut off designed within the grid. It had a darkened area that was surface damaged.
roadfrog
03-05-17 06:28 PM
