Question DIY-ers
Old 12-02-15, 09:49 AM
dag8882
dag8882's Avatar
Default Question DIY-ers
Good morning Club lexus!
Well I got my first ever check engine light In this car! Which is not the greatest thing but I figured after 10yrs of ownership, 1st CEL, not too shabby!
Anyhow, after using code scanner found out it was due to misfires of the ignition coils so we suspect... My question is is it possible for do-it-yourselfers to change out the ignition coils and spark plugs or is it best off being done by a professional mechanic?
Thanks and advance for any and all advice given.
-DAG
Old 12-02-15, 10:26 AM
Coleroad
Coleroad's Avatar
It is easy on this car. Do it yourself, save that money for family over Christmas.
Old 12-02-15, 10:36 AM
dag8882
dag8882's Avatar
Thanks for the quick response!
Even better to hear that it's an easy task!
Don't want to sound like an idiot but could you emphasize a slight bit more on how easy of a task it is... Or what the procedure is ?
Many many thanks!
Old 12-02-15, 10:37 AM
Coleroad
Coleroad's Avatar
Take the cover off the top of the engine. The drivers side is right there nothing in the way. Passengers side remove the air box. If you have trouble with the back plug on passenger side you can take the battery out for more room.i find it easier to take the wire plug off of the coil before unbolting it.
Old 12-02-15, 10:42 AM
Coleroad
Coleroad's Avatar
The air box that needs to come out.
Old 12-02-15, 10:43 AM
Coleroad
Coleroad's Avatar
Drivers side nothing in the way.
Old 12-02-15, 10:47 AM
Coleroad
Coleroad's Avatar
The engine cover comes off with just two 10mm nuts.
Old 12-02-15, 11:04 AM
Coleroad
Coleroad's Avatar
Here is a full write up by. If you read on page two it will tell you how to remove the air box . His had an aftermarket air intake on it. That is why his pictures look a little different.
https://www.clublexus.com/forums/sc4...ent-diy-2.html
hsmac
RX - 1st Gen (1999-2003)
08-13-19 09:18 AM
PortAh
05-20-19 12:27 PM
jclar2003
02-04-17 12:43 AM
mikegbuff
01-25-13 03:46 PM
LADavidGS
06-30-12 05:35 PM
Quick Reply: Question DIY-ers
