Mystery: interior map lights
Old 12-21-15, 03:08 AM
OBP
OBP's Avatar
Or you can get an LED board like mine and BB430s and just switch the wires between the BA9 base and the board itself. No need to dig around in the housing and work on the car's wiring. Worked well for me. Good luck which ever way you go. Best mod to do - makes a huge difference.
BTW on the boards, I attached four little plastic teeth to the ends of it so they sit on the plastic lens - that way the LEDs do not have to touch the plastic lens. Not sure if really needed but did not want to have to open it up again or buy a new lens so took the extra step.
Old 12-21-15, 05:41 AM
Retroplay
Retroplay's Avatar
I did pretty much the same as BB430, but with 9 LEDs. I then removed the bulb bracket and soldered the LEDs in place on the back side.
The map light is wired with the tip being negative and the clip being positive. This is the opposite of nearly all LED kits out there. However, if they use a bridge rectifier inside the bulb (or make the rectifier out of the LEDs) then it would be non-dependent on polarity. In the case of using the LEDs as the bridge, only half the LEDs would light.
With a diode rectifier, the voltage would be reduced, hence dimmer bulb. If they used the LEDs as a rectifier, then only half the blubs would light, thus being dimmer.
You can solve the problem in one of three ways:
1. Purchase LEDs with the correct polarity
2. Puchase on of the LED bars which usually comes with a pigtail connector that you can flip to reverse the polarity
3. Rewire your maplight to the more common polarity.
I first chose #3, but then went to #2. I was very satisfied with the brightness, but with the bracket in there, the light was not even. So, I modified it and soldered the LED bar in place.
Old 12-21-15, 05:50 AM
Retroplay
Retroplay's Avatar
Also a note: If someone needs my attention or help, please shoot me a PM and I will get an email notification. I have been extremely busy lately and have not had time to hang out here or do much with the SC430 lately But if you ask for my help, I will be glad to respond.
Hopefully that will change soon after the New Year.
Old 12-21-15, 02:17 PM
2ksoftail
2ksoftail's Avatar
Default My Bad
I hit this problem 2yr ago when changing my domes to LED. Sorry for not posting. I changed the wiring polarity inside my domes rather than sourcing reverse polarity blubs. Don't have to remember if I ever go back to Incan's. Can use any standard led.
Old 12-21-15, 04:01 PM
mrblister
mrblister's Avatar
My LED kit came with a bayonet style clip in accessory that you then pluged the wedge style LED if iT did not work you just turn the bayonet 180 degrees and it worked. My sc 430 was a 2005
Old 01-14-22, 08:05 PM
jszachar
jszachar's Avatar
Originally Posted by GmanSC
I previously purchased the LED bulbs for my map lights P/N BA9s-x4-x-xVAC-CAR (https://www.superbrightleds.com/more...c-car-bulbs/6/) , and they worked fine, just litte too dim. I then purchased the replacement P/N BA9s-xHP5-CAR (https://www.superbrightleds.com/more...ofit-car/2077/), installed in the car and they did not work. Thinking I got the bad bulbs, I tested the P/N BA9s-xHP5-CAR with external power supply, and they were good. Somehow, it doesn't work when installing them in the car, while the P/N BA9s-x4-x-xVAC-CAR works fine.
I'm baffled, I don't know why and can't explain????
May be the good engineer Retro could explain.
One of my ceiling bulbs, I think, is burnt. I don't know how to get access to it. This quadratic cover seems sealed pretty hard. Please help. Thanks.
Old 01-14-22, 08:55 PM
GmanSC
GmanSC's Avatar
It’s quite easy. Locate the tabs along the edges. Insert the thin blade screwdriver then pry the cover off.
jszachar (01-14-22)
Old 01-14-22, 09:23 PM
jszachar
jszachar's Avatar
Many thanks. Did at last. Pretty confusing.
Abied
08-05-15 08:08 AM
Xwakeboard
03-09-11 09:25 AM
SlickRSM
03-16-09 03:48 PM
C. McHale
Lighting
03-10-09 02:59 PM
PNice972
06-03-06 10:33 PM
Quick Reply: Mystery: interior map lights
