Moisture behind screen, clean???
Has anyone ever taken the info/control screen apart. I have a very small amount of moisture that only shows under certain light conditions. Would like to get rid of it, but not bad enough to take to my $80hr dealer. Suggestions? Thanks in advance.
You think maybe some silicone from armor all or similar product got on it . One time when I had mine detailed they used some it was spotty on that and the radio screen. Mean green got it taken care of on the radio. I was worse on the heater screen. I never could get it to look right from cleaning. Like you said its when the sun hits it right you can see it. I finally used plastx for headlights on it . It Did remove the coating on it too though. It looks fine to me I didn't regret the anti glare coating coming off.
Switch that around, the radio screen is the one I used the plastx on, not the heater screen.
My A/C control screen on both the one that came on the car and the replacement had a lot of discoloration in the anti-glare coating. I removed it and cut a new plastic window from some anti-glare plexi (meant for picture frames) I picked up from Menards.
If you are careful, it is not a big deal to take the AC controls apart and the easiest part to get to is that front panel to clean your screen.
