Various ECU Pinouts
Old 02-14-16, 01:19 PM
Retroplay
Retroplay's Avatar
Default Various ECU Pinouts
I am not sure if others will find this useful or not, but I have been putting together collections of easy to read pinouts for the various ECUs and electronics in the SC430.
This information can be found spread around various sources but it is rare to find it all in just one place. My goal is to try to collect all that information into single sheet pinouts as complete as possible.
I thought that I would share them as I make them here.
Each one will be a picture(s) as well as an attached excel spreadsheet.
I will likely update them with added information (or missing pins) as I discover new sources.
I am also hoping to add connector part numbers whenever possible.
If you know about any extra information (ie. the missing pins) or see an error, please let me know.
The following 2 users liked this post by Retroplay:
MattInLex (07-15-21), rlsc430 (10-04-21)
Old 02-14-16, 01:23 PM
Retroplay
Retroplay's Avatar
Default A/C Control Assembly Pinout
Connector Part Numbers
A8 90980-11915
A9 90980-11913
A10 90980-11911
File Type: xlsx
rlsc430 (10-04-21)
Old 02-14-16, 01:32 PM
Retroplay
Retroplay's Avatar
Default DLC3 Pinout
J1962 Standard OBDII Connector
ISO 9141-2 Protocol Standard
J2534-1 and -2 API ECU programming interface
rlsc430 (10-04-21)
Old 02-14-16, 01:38 PM
Retroplay
Retroplay's Avatar
Default Network Gateway ECU pinout
Mating connector PN 90980-11915
Ties all networks together:
AVC-LAN (Audio/Video/Control Local Area Network)
BEAN (Body Electronics Area network)
ISO 9141-2 (OBDII Diagnostics Interface)
File Type: xlsx
rlsc430 (10-04-21)
Old 02-16-16, 10:00 AM
TarheelNic
TarheelNic's Avatar
information that's certainly "worthy" of a sticky, IMO.
_____________________________
2007 SC430
Starfire Pearl/Ecru
Vais SLX w/XM;
NavTool 3.0-HDMI for AppleTV,
BU Camera & BlindSpot Cam.
Old 02-16-16, 11:24 AM
Retroplay
Retroplay's Avatar
Thanks. Hopefully some others will tackle a pinout here and there in the same format and add to the thread. Otherwise it will be awhile before this thread is finished.
Old 02-16-16, 11:51 AM
TarheelNic
TarheelNic's Avatar
I'm game. I'll start working on the one I've had the most experience with: The Roof ECU (2007)
I'll add the "year-info" to mine, as I've discovered there seem to be some subtle deviations in them, or at least there seemed to be in the AC-Controller ECUs, between the 2005 and 2007 models....
2007 SC430
Starfire Pearl/Ecru
Vais SLX w/XM;
Old 02-16-16, 03:00 PM
Retroplay
Retroplay's Avatar
Good point about the year. I appreciate the help. The roof ECU was the next one I was going to tackle. Since mine is a 2003, I will compare yours and if there is a difference, I will add the 2003.
Old 02-17-16, 03:47 PM
TarheelNic
TarheelNic's Avatar
Default 2007 Roof ECU
I would pick one with ~80 pins to identify....
2007 SC430
Starfire Pearl/Ecru
Vais SLX w/XM;
File Type: xlsx
Swishh
12-03-21 04:03 PM
waeel
05-06-16 12:31 PM
Firemr2
SC- 1st Gen (1992-2000)
12
01-10-16 09:44 PM
muddyh2o
IS - 1st Gen (2001-2005)
08-17-01 09:43 AM
Quick Reply: Various ECU Pinouts
