2002 SC430 Gauge / Radio / climate control Backlight Question?
Just picked up a pretty nice 2002 sc430 today. On the drive home I realized all the dash backLights are not lighting up. However the The radio and climate control unit do have a dim backlight working but is stuck at one level of illumination.
Like most cars the all dash lights should be very bright during the day and when you turn on the headlights they should all Dim down. ..... Not on this SC.
Makes no difference what position the headlight switch is in....Nothing changes or lights up
and
The little Dimmer **** does nothing either when turned all the way one way or the other.
Anyone have any ideas?? Fuses? Im not sure what to try.
Thanks
and
Thanks
and
Thanks
and
Thanks
Either wait for darkness or put it in a dark garage to be sure you have a problem.
On my 2002, the dash pod back lights are non existent during the day; and gauges are harder to read. At night they work as they should; on later years they made the dash pod lights much brighter during daytime.
Are you saying you fixed something with the dimmer switch that makes them brighter during the day without headlights on in normal driving?
Dealer had always told me Lexus just screwed up and didn't install bright back lights until maybe the 05 or 06 years.
thanks!
Dave H.
thanks!
Dave H.
Hi, just bought 04 SC430 and same issue with dash lights not bright enough. I suspect that dimmer switch as it does nothing when turned. How do you pop it out as someone mentioned to disconnect? Also has anybody bought one through Toyota part number for less money if I need to replace and if so Toyota part #?
Thanks!
Thanks!
Have you look on eBay? There are several used one there. I can not help with the install though.
And they are very cheap on ebay. Just search SC430 dimmer
Ok great! Thank you guys! I am figuring I always want it on the brightest setting, so maybe just disconnect and leave disconnected and it should stay at full brightness, correct? Otherwise will buy one on ebay as suggested.
Yes. The disadvantage is that your NAV display won't auto-dim at night.
The brightness on the instruments is also controlled by a round plastic light sensor located on the passenger side top of the dash near windshield. Covering the sensor will make the car think its dark outside and brighten the gauge cluster however it likely also dims the NAV system. It might be possible to rig a toggle switch to defeat (or enable) just the light sensor signal going to the gauge cluster and not the other lighted items like NAV, if this could be done it might be possible to have the gauge cluster lights up during daylight without affecting the NAV and other lights.
That's good to hear foreste1, I'm glad that you got it working. It probably just had a dirty contact.
Luckily, I have an 07. None of this problem.
