bracket for Willowwood brake caliper?
You can install any caliper, but the brakes need to clear the wheels;
which prevents most installs.
Hats can be made to adapt any calipers easily, but you'll need some
wheels with interesting offsets.
You can have a machine shop make it but let me tell ya, from experience, it's a little involved. You have to secure your rotor and hat before you start and make sure everything clears...
Your offset won't matter if it's a low disk...how much clearance do you have from the inside face of your wheel to the caliper? Most large caliper setups require a HIGH DISK setup on the wheels...
6 piston Brembo? Not 4 piston?
Din - I ended up getting the 14" StopTech setup...I'll be posting a full review in my SC400 Project Car article...along with a little tour of StopTech's facility...
istundra
Wheels, Tires & Brakes Forum
06-18-09 10:25 AM
