2002 sc430 trunk and hardtop issue
Hi all. First off, I am not sure if both of these issues are related to each other.
I'll start with the trunk problem. A couple months ago I started having issues with the trunk not opening right away. It started taking a couple of times of pressing the key fob and the interior trunk switch to be able to open the trunk. I noticed during that time that it would open easier during hot days and on cold days it would take more tries. Now it has stopped opening completely with both the keyfob and the switch. I hear the beep, and i hear the trunk clicking. But it just wouldn't open. Only the manual way to open it through, the glovebox works. I have researched this and I have tried disconnecting the batteries and fiddling with the valet switch as well to try to fix it. But to no avail. Any ideas?
Now on to the hardtop. Started having an issue with opening the hardtop. The motors engage and it tries to open but it looked like it was getting stuck about 1 inch movement from closed position. I ended up having to push it up with a decent amount of force until i hear a loud pop from there on, it continues to open all the way. Same thing with the trunk back then, hotter weather worked easier, But would still hear a pop though not as loud If the weather was cold. Partially thinking there is a lubrication issue although when i checked the hooks it did have a decent amount of grease which was of yellowish color similar to the trunk latch.
Does anybody have any idea on how to fix my problems? Would appreciate any suggestions on how to fix them. Thanks!
-Bryan
-Bryan
The trunk pop is probably bad struts, unless like you were thinking that something is causing it to stick.
Try lifting up on the trunk while you press the button and see if it opens easier. If not, it could be that the latch is not fully releasing. We had a member earlier whose latch had come loose partially causing a similar problem. (Seems like that was within the last 6 months to a year.)
Harold 's probably right. Check the latch. When the trunk operates correctly, the roof top will also operates.
I have a problem with opening the trunk with the key fob. Push the trunk button, nothing's happened. Anyone knows why? The key opens and locks doors fine.
I've havent really tried taking the top down recently, but i was wondering if the trunk latch has to open when the trunk opens for the hardtop to go down.
Valet switch? Does it make a beep and click or no sound at all? Does it open from the button from inside the car?
It sounds like electrical problem than mechanical problem since you can open it from center console. You might want to look for the blown fuse.
I found out what's wrong with the remote trunk release button: nothing wrong at all. You need to push and hold the button for more than a second to open the trunk. This button does not work like the lock and unlock button.
Ha, just a operator err !!!!
You can have that changed in the personal setting so that one press no hold will open it
Yes, MrB is correct, Tech Stream Can change all of the settings.
I think there could be some annoyances if it was one press function only. Many times i've pressed the lock or unlock button on accident. Not a big deal since i can just press it to lock or unlock the doors. But if you press the trunk button on accident you have to come back to your car close the trunk. But maybe thats just clumsy me.
This has happened to the best of us!
