Tachometer Needle Sticking
The tachometer needle in my 2002 SC just started sticking. Has anyone else had this problem and if so what did you do to resolve it?
That write up is not relevant for this model.
We can repair the cluster if you send it in. Cost will probably be $99 plus shipping to repair the tach movement.
Contact us if interested or just send it in with a work order: http://taninauto.com/media/work_order.pdf
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
www.taninautoelectronix.com
![](https://www.clublexus.com/forums/signaturepics/sigpic178522_1.gif)
262-456-4147
Hi Tanin Auto Electronix
Thank you very much for the posting. I will take you up on your offer this spring when I can be without my car for a week or so. Its my daily driver so I'll need to wait for some better weather so I can ride my motorcycle to work while you have the cluster. Now all I have to do is score a shop manual somewhere so I can learn the proper way to remove the instrument cluster. I see another post shaping up......
Thanks Again!
Thanks Again!
Thanks Again!
Thanks Again!
We have this diagram for removing the cluster, if this helps at all.
![](https://cimg5.ibsrv.net/gimg/www.clublexus.com-vbulletin/875x522/forumpix_ac8b4a53fc141f63aebd9c120b795bc6b084a649.jpg)
Let us know if you have technical questions as you remove it too and we can walk you through it.
Thanks,
__________________
262-456-4147
262-456-4147
Daspyda
12-05-14 05:25 PM
